Help w/ JTAPI metacodes translation
Where can I find explination or translation on JTAPI metacodes ?
For instance 128, 129, 131, 134
and
GMT %JTAPI-JTAPIIMPL-7-UNK:(P1-NLSS_user017) GCID=(2,3522960)->ACTIVECallManager.deliverEvents: deliver 2 events with METACODE 134
Re
Kjartan
Everyone's tags (3)
Green
Re: Help w/ JTAPI metacodes translation
Cisco Developers guide provide information about those events:
Interface javax.telephony.events.Ev
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/jtapi_dev/7_1_2/jt_extsn.html
Theres no table for each metacode and its numeric association, but other JTAPI traces should display the proper metacode describing the state of the call,
if that information is not there (public) and you require more info you may need to contact/open a case with JTAPI dev team.
Is there any reason you want to use those numbers?
I´m beginging to hunt down the reason why a "linestates" are failing from an CUCM4 and a Netwise CMG/CTC operator console system/application and was just wondering if thouse indicated perhaps errors or just normal states in between the systems (perhaps like ITU cause values) since the log indicates that x number of calls was delivered with metacode y. But perhaps this has more to do with callhandling than callstates?
516
