Community Member
Help with a voice translation rule
I have a gateway that has a PRI attached and it receives inbound calls for 2 DID blocks. 1[89]XX and 1[45]XX. I need to write a translation rule for SRST that will pass any calls received for 1[89]XX through just like it was received (XXXX) and will append a 3 to the beginning of anything that is received for 1[45]XX so it will look like 31[45]XX. I suck at translation rules and my gateway gatekeeper book is in another state. Can someone help me out?
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Help with a voice translation rule
Pick one:
rule 1 /^14/ /314/
rule 2 /^15/ /315/
or
rule 1 /^1\([45]\)/ /31\1/
The 1[89]xx doesn't fall in that and goes unchanged.
Try rules first with "test voice translation-rule XXX .
1 REPLY
Pick one:
rule 1 /^14/ /314/
rule 2 /^15/ /315/
or
118
