Hi All,
I a cucm and with srst configure. i had my inbound and outbound using my e1 isdn and a few analog lines as backup. during srst mode phones are able to registe and make a call internal. i had my inbound via e1 and analog. But i could only make outbound calls using my analog lines. i tried using ports and trunk-group on my config but still it did not work.
i have to my dial-peer to use e1 but calls could not pass through. the simulate srst mode, I disconnect my call manager on the network via vmware client. When i returned the connection i can make outbound calls using e1.
Below are my config.
Seafdec_2901VG#sh
boot-start-marker
boot-end-marker
card type e1 0 0
enable secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
no aaa new-model
clock timezone Ph 8 0
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
ip cef
no ip domain lookup
no ipv6 cef
isdn switch-type primary-net5
trunk group E1_PLDT
hunt-scheme longest-idle
trunk group Analog_Globe
crypto pki trustpoint TP-self-signed-3041017873
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3041017873
revocation-check none
rsakeypair TP-self-signed-3041017873
crypto pki certificate chain TP-self-signed-3041017873
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 33303431 30313738 3733301E 170D3134 30313233 30313436
31375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 30343130
31373837 3330819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100CD99 A439343A A78C89E7 A8D8104B 6C205AA1 7EC0160C 86CEE3AB 83419E88
14D1DB71 B775A208 0AF83A63 472C171F 8AF8BB44 49C9B5C1 86A8577F 6C4748E5
C166E6E8 D1FBB4B8 45CFBE36 2651E00E 8D856744 3E953B58 10D09BB0 D1ADFD12
68EA8689 C3E1CF2C 21EC9519 E5B085E2 6187C264 A1148F5C BAF14909 39493343
82450203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 14201CA9 DE45C548 2F30106A 8344142A 1407B81C BA301D06
03551D0E 04160414 201CA9DE 45C5482F 30106A83 44142A14 07B81CBA 300D0609
2A864886 F70D0101 05050003 81810098 72D7BC17 3544D384 A426EFBF 5AED3590
9923DC8A 215B9EF1 498324A5 F7B9185D 48D11C81 DBD69518 D141B916 F16718C0
494C233A 50D9E7A3 4CFC68CF 0DF0C534 D83D453C 03A8495D B2AEE212 9735141A
676D63A4 7D03C888 6AEEBD2D 1BBC7BE8 27570CE1 0DD8EFF8 04463E85 7E6D0506
352C1735 689B52F4 8C9D288E B06119
quit
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
call start interwork
sip
bind control source-interface GigabitEthernet0/0
bind media source-interface GigabitEthernet0/0
min-se 1200 session-expires 1200
error-passthru
registrar server expires max 600 min 60
asserted-id pai
no update-callerid
early-offer forced
history-info
no call service stop
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
voice class codec 2
codec preference 1 g729r8
codec preference 3 g711alaw
voice register global
system message Backup Mode
max-dn 30
max-pool 10
voice register pool 1
id network 192.168.0.64 mask 255.255.255.192
application sip.app
incoming called-number
dtmf-relay rtp-nte
voice-class codec 1
no vad
voice register pool 2
id network 10.0.0.0 mask 255.255.0.0
application sip.app
dtmf-relay rtp-nte
voice-class codec 1
no vad
voice register pool 3
id network 172.30.0.0 mask 255.255.0.0
application sip.app
dtmf-relay rtp-nte
voice-class codec 1
no vad
voice register pool 4
id network 10.0.6.0 mask 255.255.254.0
application sip.app
dtmf-relay rtp-nte
voice-class codec 1
no vad
application
global
service alternate Default
hw-module pvdm 0/0
redundancy
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31 service mgcp
interface Embedded-Service-Engine0/0
no ip address
shutdown
ip address 192.168.0.75 255.255.255.192
duplex auto
speed auto
h323-gateway voip interface
interface GigabitEthernet0/1
ip address 192.168.28.81 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
isdn bchan-number-order ascending
trunk-group E1_PLDT
no cdp enable
ip default-gateway 192.168.0.65
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.0.65
ip route 192.168.100.0 255.255.255.0 192.168.0.80
control-plane
call fallback active
voice-port 0/0/0:15
cptone PH
connection plar 1001
bearer-cap Speech
voice-port 0/1/0
trunk-group Analog_Globe
secondary dialtone
no battery-reversal
no vad
timeouts call-disconnect 1
timeouts wait-release 1
timing hookflash-out 50
timing guard-out 1000
connection plar 1434
caller-id enable
voice-port 0/1/1
secondary dialtone
no battery-reversal
no vad
caller-id enable
voice-port 0/1/2
secondary dialtone
no battery-reversal
no vad
caller-id enable
voice-port 0/1/3
secondary dialtone
no battery-reversal
no vad
caller-id enable
voice-port 0/2/0
secondary dialtone
no battery-reversal
no vad
connection plar 8000
description test
station-id name 511-9170
caller-id enable
voice-port 0/2/1
secondary dialtone
no battery-reversal
no vad
caller-id enable
voice-port 0/2/2
secondary dialtone
no battery-reversal
no vad
caller-id enable
voice-port 0/2/3
secondary dialtone
no battery-reversal
no vad
caller-id enable
ccm-manager fallback-mgcp
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 192.168.0.70
ccm-manager config
mgcp
mgcp call-agent 192.168.0.70 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp profile default
dspfarm profile 1 transcode
associate application SCCP
shutdown
dspfarm profile 2 conference
shutdown
dial-peer voice 999010 pots
service mgcpapp
port 0/1/0
dial-peer voice 999011 pots
service mgcpapp
port 0/1/1
dial-peer voice 999012 pots
service mgcpapp
port 0/1/2
dial-peer voice 999013 pots
service mgcpapp
port 0/1/3
dial-peer voice 999020 pots
service mgcpapp
port 0/2/0
dial-peer voice 999021 pots
service mgcpapp
port 0/2/1
dial-peer voice 999022 pots
service mgcpapp
port 0/2/2
dial-peer voice 999023 pots
service mgcpapp
port 0/2/3
dial-peer voice 11 pots
description city calls
destination-pattern 9[2-9]......
port 0/0/0:15
forward-digits 7
dial-peer voice 12 pots
trunkgroup E1_PLDT 1
trunkgroup Analog_Globe 2
description manila calls
destination-pattern 902.......
forward-digits 9
dial-peer voice 13 pots
description ndd calls
destination-pattern 90[3-8]........
forward-digits 10
dial-peer voice 14 pots
description mobile calls
destination-pattern 909.........
forward-digits 11
dial-peer voice 15 pots
description Toll free calls
destination-pattern 1800.......
forward-digits 11
dial-peer voice 16 pots
description idd calls
destination-pattern 00T
forward-digits all
dial-peer voice 22 pots
forward-digits 9
dial-peer voice 23 pots
forward-digits 10
dial-peer voice 24 pots
forward-digits 11
dial-peer voice 25 pots
forward-digits 11
dial-peer voice 26 pots
forward-digits all
num-exp 0 1000
gatekeeper
shutdown
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
timeouts interdigit 5
timeouts busy 3
ip source-address 192.168.0.75 port 2000
max-ephones 42
max-dn 200
application default
system message primary System on Backup Mode
system message secondary Backup Mode
transfer-pattern ....
time-zone 41
In SRST, can you do a test call and send us the ff:
debug vpm signal
debug voip ccapi inout
Ayodeji,
i will do that today during lunch break. In the meantime, I notice during srst mode I was was able to make outbound and inbound on my analog ports but only inbound calls on my e1 isdn line. I coud be missing some config on my dial-peer, your thoughts?
Is digit auto stripping is still applicable on e1? how about i send you the "show dialplan number xxxxxx"
Ayodeji,
i made changes on my serial interface and remove alll dial-peer and added only 1 for isdn
no ip address
encapsulation hdlc
no cdp enable
dial-peer voice 999101 pots
destination-pattern 9.......
port 0/0/0:15
below are the output of the debug command
Mar 31 04:56:23.453: htsp_process_event: [50/0/1.1, EFXS_ONHOOK, E_DSP_SIG_1100]efxs_onhook_offhook htsp_setup_ind
Mar 31 04:56:23.453: [50/0/1.1] get_local_station_id calling num=1001 calling name=1001 calling time=03/31 12:56 orig called=
Mar 31 04:56:23.453: //-1/A45319F88E9D/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=1001
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=0 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
Mar 31 04:56:23.457: //-1/A45319F88E9D/CCAPI/cc_api_call_setup_ind_common:
Interface=0x3DFD2BF0, Call Info(
Calling Number=1001,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
Incoming Dial-peer=20001, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Mar 31 04:56:23.457: //-1/A45319F88E9D/CCAPI/ccCheckClipClir:
In: Calling Number=1001(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=1001(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Mar 31 04:56:23.457: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 31 04:56:23.457: :cc_get_feature_vsa malloc success
Mar 31 04:56:23.457: cc_get_feature_vsa count is 1
Mar 31 04:56:23.457: :FEATURE_VSA attributes are: feature_name:0,feature_time:1050709696,feature_id:253
Mar 31 04:56:23.457: //3154/A45319F88E9D/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=1001(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown))
Mar 31 04:56:23.457: //3154/A45319F88E9D/CCAPI/cc_process_call_setup_ind:
Event=0x3D498160
Mar 31 04:56:23.457: //3154/A45319F88E9D/CCAPI/ccCallSetContext:
Context=0x3C2CA8A4
>>>>CCAPI handed cid 3154 with tag 20001 to app "_ManagedAppProcess_Default"
Mar 31 04:56:23.457: //3154/A45319F88E9D/CCAPI/ccCallSetupAck:
Call Id=3154
Seafdec_2901VG#3154/A45319F88E9D/CCAPI/cc_api_set_transfer_info:
Transfer Number=, Transfer Reason=0x0
Mar 31 04:56:23.457: //3154/A45319F88E9D/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=TRUE, Tone=Dial Tone,
Tone Direction=Network, Params=0x0, Call Id=3154
Mar 31 04:56:23.457: //3154/A45319F88E9D/CCAPI/ccSetDigitTimeouts:
Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
Mar 31 04:56:23.457: //3154/A45319F88E9D/CCAPI/ccCallReportDigits:
(callID=0xC52, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Call Id=3154
Mar 31 04:56:23.457: //3154/A45319F88E9D/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x3DFD2BF0, callID=0xC52, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Disposition=0x0, Interface=0x3DFD2BF0, Call Id=3154
Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=5000(ms))
Mar 31 04:56:23.457: htsp_process_event: [50/0/1.1, EFXS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]efxs_check_auto_call
Mar 31 04:56:24.409: //3154/A45319F88E9D/CCAPI/cc_api_call_digit_begin:
Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1,
Source Call Id=3154, Digit=9, DigitBeginFlags=0x0,
Rtp Timestamp=0x1A0428, Rtp Expiration=0x0
Mar 31 04:56:24.409: //3154/A45319F88E9D/CCAPI/cc_api_call_digit_end:
Source Call Id=3154, Digit=9, Duration=100,
Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Call Entry(Handoff Depth=0)
Mar 31 04:56:24.409: htsp_digit_ready(50/0/1.1): digit = 9
Mar 31 04:56:24.609: //3154/A45319F88E9D/CCAPI/cc_api_call_digit_begin:
Source Call Id=3154, Digit=3, DigitBeginFlags=0x0,
Rtp Timestamp=0x1A8128, Rtp Expiration=0x0
Mar 31 04:56:24.609: //3154/A45319F88E9D/CCAPI/cc_api_call_digit_end:
Source Call Id=3154, Digit=3, Duration=100,
Mar 31 04:56:24.609: htsp_digit_ready(50/0/1.1): digit = 3
Mar 31 04:56:24.809: //3154/A45319F88E9D/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x1AFE28, Rtp Expiration=0x0
Mar 31 04:56:24.809: //3154/A45319F88E9D/CCAPI/cc_api_call_digit_end:
Mar 31 04:56:24.809: htsp
Seafdec_2901VG#_digit_ready(50/0/1.1): digit = 3
Mar 31 04:56:25.009: //3154/A45319F88E9D/CCAPI/cc_api_call_digit_begin:
Source Call Id=3154, Digit=7, DigitBeginFlags=0x0,
Rtp Timestamp=0x1B7B28, Rtp Expiration=0x0
Mar 31 04:56:25.009: //3154/A45319F88E9D/CCAPI/cc_api_call_digit_end:
Source Call Id=3154, Digit=7, Duration=100,
Mar 31 04:56:25.009: htsp_digit_ready(50/0/1.1): digit = 7
Mar 31 04:56:25.209: //3154/A45319F88E9D/CCAPI/cc_api_call_digit_begin:
Source Call Id=3154, Digit=2, DigitBeginFlags=0x0,
Rtp Timestamp=0x1BF828, Rtp Expiration=0x0
Mar 31 04:56:25.209: //3154/A45319F88E9D/CCAPI/cc_api_call_digit_end:
Source Call Id=3154, Digit=2, Duration=100,
Mar 31 04:56:25.209: htsp_digit_ready(50/0/1.1): digit = 2
Mar 31 04:56:25.409: //3154/A45319F88E9D/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x1C7528, Rtp Expiration=0x0
Mar 31 04:56:25.409: //3154/A45319F88E9D/CCAPI/cc_api_call_digit_end:
Mar 31 04:56:25.409: htsp_digit_ready(50/0/1.1): digit = 7
Mar 31 04:56:25.609: //3154/A45319F88E9D/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x1CF228, Rtp Expiration=0x0
Mar 31 04:56:25.609: //3154/A45319F88E9D/CCAPI/cc_api_call_digit_end:
Mar 31 04:56:25.609: htsp_digit_ready(50/0/1.1): digit = 2
Mar 31 04:56:25.809: //3154/A45319F88E9D/CCAPI/cc_api_call_digit_begin:
Source Call Id=3154, Digit=5, DigitBeginFlags=0x0,
Rtp Timestamp=0x1D6F28, Rtp Expiration=0x0
Mar 31 04:56:25.809: //3154/A45319F88E9D/CCAPI/cc_api_call_digit_end:
Source Call Id=3154, Digit=5, Duration=100,
Seafdec_2901VG#Mar 31 04:56:25.809: htsp_digit_ready(50/0/1.1): digit = 5
Mar 31 04:56:25.809: //3154/A45319F88E9D/CCAPI/ccCallReportDigits:
(callID=0xC52, digit_event=0x0, enable=FALSE, consume=FALSE)
Mar 31 04:56:25.809: //3154/A45319F88E9D/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x3DFD2BF0, callID=0xC52, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Mar 31 04:56:25.809: //3154/A45319F88E9D/CCAPI/ccCallProceeding:
Progress Indication=NULL(0)
Mar 31 04:56:25.813: //3154/A45319F88E9D/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=999101, Params=0x3C2B61F4, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Mar 31 04:56:25.813: //3154/A45319F88E9D/CCAPI/ccCheckClipClir:
Destination Pattern=9......., Called Number=93372725, Digit Strip=TRUE
Called Number=93372725(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=1001
Account Number=, Final Destination Flag=FALSE,
Guid=A45319F8-B7C7-11E3-8E9D-ABA9E7B3E732, Outgoing Dial-peer=999101
Mar 31 04:56:25.813: //3154/A45319F88E9D/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-ani=1001
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=93372725
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
Mar 31 04:56:25.813: //3154/A45319F88E9D/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x3DAD23F0, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=1001,(Calling Name=1001)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=93372725(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=999101, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Mar 31 04:56:25.813: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 31 04:56:25.813: :cc_get_feature_vsa malloc success
Mar 31 04:56:25.813: cc_get_feature_vsa count is 2
Seafdec_2901VG#sa:
Mar 31 04:56:25.813: :FEATURE_VSA attributes are: feature_name:0,feature_time:1050709472,feature_id:254
Mar 31 04:56:25.813: //3155/A45319F88E9D/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Mar 31 04:56:25.813: //3155/A45319F88E9D/CCAPI/ccCallSetContext:
Context=0x3C2B61A4
Mar 31 04:56:25.813: //3154/A45319F88E9D/CCAPI/ccSaveDialpeerTag:
Mar 31 04:56:25.813: htsp_process_event: [50/0/1.1, EFXS_OFFHOOK, E_HTSP_PROCEEDING]efxs_offhook_proceeding
Mar 31 04:56:25.813: [50/0/1.1] set signal state = 0x8 timestamp = 0
Mar 31 04:56:25.925: //3155/A45319F88E9D/CCAPI/cc_api_call_disconnected:
Cause Value=21, Interface=0x3DAD23F0, Call Id=3155
Call Entry(Responsed=TRUE, Cause Value=21, Retry Count=0)
Mar 31 04:56:25.925: //3154/A45319F88E9D/CCAPI/ccCallReleaseResources:
release reserved xcoding resource.
Mar 31 04:56:25.925: //3155/A45319F88E9D/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=3155
Mar 31 04:56:25.925: //3155/A45319F88E9D/CCAPI/ccCallDisconnect:
Cause Value=21, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=21)
Cause Value=21, Call Entry(Responsed=TRUE, Cause Value=21)
Mar 31 04:56:25.925: //3155/A45319F88E9D/CCAPI/cc_api_get_transfer_info:
Transfer Number=NULL
Mar 31 04:56:26.025: //3155/A45319F88E9D/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x3DAD23F0, Tag=0x0, Call Id=3155,
Call Entry(Disconnect Cause=21, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
Mar 31 04:56:26.025: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 31 04:56:26.025: :cc_free_feature_vsa freeing 3EA08DD8
Mar 31 04:56:26.025: vsacount in free is 1
Mar 31 04:56:26.025: //3154/A45319F88E9D/CCAPI/ccCallDisconnect:
Cause Value=21, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Mar 31 04:56:26.025: //3154/A45319F88E9D/CCAPI/cc_api_get_transfer_info:
Seafdec_2901VG#
Mar 31 04:56:29.773: htsp_process_event: [50/0/1.1, EFXS_OFFHOOK, E_DSP_SIG_0100]efxs_offhook_onhook
Mar 31 04:56:29.773: htsp_timer - 10 msec
Mar 31 04:56:29.785: htsp_process_event: [50/0/1.1, EFXS_OFFHOOK, E_HTSP_EVENT_TIMER]efxs_offhook_timer
Mar 31 04:56:29.785: htsp_process_event: [50/0/1.1, EFXS_ONHOOK, E_HTSP_RELEASE_REQ]efxs_onhook_release
Mar 31 04:56:29.785: htsp_timer_stop
Mar 31 04:56:29.785: [50/0/1.1] set signal state = 0x4 timestamp = 0
Mar 31 04:56:29.785: //3154/A45319F88E9D/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x3DFD2BF0, Tag=0x0, Call Id=3154,
Seafdec_2901VG#
Mar 31 04:56:29.785: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 31 04:56:29.785: :cc_free_feature_vsa freeing 3EA08EB8
Mar 31 04:56:29.785: vsacount in free is 0
Seafdec_2901VG#
Mar 31 04:56:43.121: htsp_process_event: [50/0/1.1, EFXS_ONHOOK, E_DSP_SIG_1100]efxs_onhook_offhook htsp_setup_ind
Mar 31 04:56:43.121: [50/0/1.1] get_local_station_id calling num=1001 calling name=1001 calling time=03/31 12:56 orig called=
Mar 31 04:56:43.121: //-1/B00C33DD8EA2/CCAPI/cc_api_display_ie_subfields:
cisco-username=
cisco-ani=1001
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
Mar 31 04:56:43.121: //-1/B00C33DD8EA2/CCAPI/cc_api_call_setup_ind_common:
Mar 31 04:56:43.121: //-1/B00C33DD8EA2/CCAPI/ccCheckClipClir:
Mar 31 04:56:43.121: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 31 04:56:43.121: :cc_get_feature_vsa malloc success
Mar 31 04:56:43.121: cc_get_feature_vsa count is 1
Mar 31 04:56:43.121: :FEATURE_VSA attributes are: feature_name:0,feature_time:1050709696,feature_id:255
Mar 31 04:56:43.121: //3156/B00C33DD8EA2/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Mar 31 04:56:43.125: //3156/B00C33DD8EA2/CCAPI/cc_process_call_setup_ind:
Event=0x3D498160
Mar 31 04:56:43.125: //3156/B00C33DD8EA2/CCAPI/ccCallSetContext:
Context=0x3C2B4D34
>>>>CCAPI handed cid 3156 with tag 20001 to app "_ManagedAppProcess_Default"
Mar 31 04:56:43.125: //3156/B00C33DD8EA2/CCAPI/ccCallSetupAck:
Call Id=3156
Mar 31 04:56:43.125: //3156/B00C33DD8EA2/CCAPI/cc_api_set_transfer_info:
Mar 31 04:56:43.125: //3156/B00C33DD8EA2/CCAPI/ccGenerateToneInfo:
Tone Direction=Network, Params=0x0, Call Id=3156
Mar 31 04:56:43.125: //3156/B00C33DD8EA2/CCAPI/ccSetDigitTimeouts:
Mar 31 04:56:43.125
Seafdec_2901VG#: //3156/B00C33DD8EA2/CCAPI/ccCallReportDigits:
(callID=0xC54, digit_event=0x1, enable=TRUE, consume=FALSE)
Mar 31 04:56:43.125: //3156/B00C33DD8EA2/CCAPI/ccCallReportDigits:
Enabled=TRUE, Call Id=3156
Mar 31 04:56:43.125: //3156/B00C33DD8EA2/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x3DFD2BF0, callID=0xC54, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Disposition=0x0, Interface=0x3DFD2BF0, Call Id=3156
Mar 31 04:56:43.125: htsp_process_event: [50/0/1.1, EFXS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]efxs_check_auto_call
Mar 31 04:56:44.009: //3156/B00C33DD8EA2/CCAPI/cc_api_call_digit_begin:
Source Call Id=3156, Digit=9, DigitBeginFlags=0x0,
Rtp Timestamp=0x1E70F8, Rtp Expiration=0x0
Mar 31 04:56:44.009: //3156/B00C33DD8EA2/CCAPI/cc_api_call_digit_end:
Source Call Id=3156, Digit=9, Duration=100,
Mar 31 04:56:44.009: htsp_digit_ready(50/0/1.1): digit = 9
Mar 31 04:56:44.285: //3156/B00C33DD8EA2/CCAPI/cc_api_call_digit_begin:
Source Call Id=3156, Digit=3, DigitBeginFlags=0x0,
Rtp Timestamp=0x1EEDF8, Rtp Expiration=0x0
Mar 31 04:56:44.285: //3156/B00C33DD8EA2/CCAPI/cc_api_call_digit_end:
Source Call Id=3156, Digit=3, Duration=100,
Mar 31 04:56:44.285: htsp_digit_ready(50/0/1.1): digit = 3
Mar 31 04:56:44.409: //3156/B00C33DD8EA2/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x1F6AF8, Rtp Expiration=0x0
Mar 31 04:56:44.409: //3156/B00C33DD8EA2/CCAPI/cc_api_call_digit_end:
Mar 31 04:56:44.409: htsp
Mar 31 04:56:44.609: //3156/B00C33DD8EA2/CCAPI/cc_api_call_digit_begin:
Source Call Id=3156, Digit=7, DigitBeginFlags=0x0,
Rtp Timestamp=0x1FE7F8, Rtp Expiration=0x0
Mar 31 04:56:44.609: //3156/B00C33DD8EA2/CCAPI/cc_api_call_digit_end:
Source Call Id=3156, Digit=7, Duration=100,
Mar 31 04:56:44.609: htsp_digit_ready(50/0/1.1): digit = 7
Mar 31 04:56:44.809: //3156/B00C33DD8EA2/CCAPI/cc_api_call_digit_begin:
Source Call Id=3156, Digit=2, DigitBeginFlags=0x0,
Rtp Timestamp=0x2064F8, Rtp Expiration=0x0
Mar 31 04:56:44.809: //3156/B00C33DD8EA2/CCAPI/cc_api_call_digit_end:
Source Call Id=3156, Digit=2, Duration=100,
Mar 31 04:56:44.809: htsp_digit_ready(50/0/1.1): digit = 2
Mar 31 04:56:45.009: //3156/B00C33DD8EA2/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x20E1F8, Rtp Expiration=0x0
Mar 31 04:56:45.009: //3156/B00C33DD8EA2/CCAPI/cc_api_call_digit_end:
Mar 31 04:56:45.009: htsp_digit_ready(50/0/1.1): digit = 7
Mar 31 04:56:45.209: //3156/B00C33DD8EA2/CCAPI/cc_api_call_digit_begin:
Rtp Timestamp=0x215EF8, Rtp Expiration=0x0
Mar 31 04:56:45.209: //3156/B00C33DD8EA2/CCAPI/cc_api_call_digit_end:
Mar 31 04:56:45.209: htsp_digit_ready(50/0/1.1): digit = 2
Mar 31 04:56:45.409: //3156/B00C33DD8EA2/CCAPI/cc_api_call_digit_begin:
Source Call Id=3156, Digit=5, DigitBeginFlags=0x0,
Rtp Timestamp=0x21DBF8, Rtp Expiration=0x0
Mar 31 04:56:45.409: //3156/B00C33DD8EA2/CCAPI/cc_api_call_digit_end:
Source Call Id=3156, Digit=5, Duration=100,
Seafdec_2901VG#Mar 31 04:56:45.409: htsp_digit_ready(50/0/1.1): digit = 5
Mar 31 04:56:45.409: //3156/B00C33DD8EA2/CCAPI/ccCallReportDigits:
(callID=0xC54, digit_event=0x0, enable=FALSE, consume=FALSE)
Mar 31 04:56:45.409: //3156/B00C33DD8EA2/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x3DFD2BF0, callID=0xC54, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Mar 31 04:56:45.409: //3156/B00C33DD8EA2/CCAPI/ccCallProceeding:
Mar 31 04:56:45.413: //3156/B00C33DD8EA2/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=999101, Params=0x3C2B7664, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Mar 31 04:56:45.413: //3156/B00C33DD8EA2/CCAPI/ccCheckClipClir:
Guid=B00C33DD-B7C7-11E3-8EA2-ABA9E7B3E732, Outgoing Dial-peer=999101
Mar 31 04:56:45.413: //3156/B00C33DD8EA2/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-ani=1001
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=93372725
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
Mar 31 04:56:45.413: //3156/B00C33DD8EA2/CCAPI/ccIFCallSetupRequestPrivate:
Mar 31 04:56:45.413: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 31 04:56:45.413: :cc_get_feature_vsa malloc success
Mar 31 04:56:45.413: cc_get_feature_vsa count is 2
Seafdec_2901VG#sa:
Mar 31 04:56:45.413: :FEATURE_VSA attributes are: feature_name:0,feature_time:1050709472,feature_id:256
Mar 31 04:56:45.413: //3157/B00C33DD8EA2/CCAPI/ccIFCallSetupRequestPrivate:
Mar 31 04:56:45.413: //3157/B00C33DD8EA2/CCAPI/ccCallSetContext:
Context=0x3C2B7614
Mar 31 04:56:45.413: //3156/B00C33DD8EA2/CCAPI/ccSaveDialpeerTag:
Mar 31 04:56:45.413: htsp_process_event: [50/0/1.1, EFXS_OFFHOOK, E_HTSP_PROCEEDING]efxs_offhook_proceeding
Mar 31 04:56:45.413: [50/0/1.1] set signal state = 0x8 timestamp = 0
Mar 31 04:56:45.525: //3157/B00C33DD8EA2/CCAPI/cc_api_call_disconnected:
Cause Value=21, Interface=0x3DAD23F0, Call Id=3157
Mar 31 04:56:45.529: //3156/B00C33DD8EA2/CCAPI/ccCallReleaseResources:
Mar 31 04:56:45.529: //3157/B00C33DD8EA2/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=3157
Mar 31 04:56:45.529: //3157/B00C33DD8EA2/CCAPI/ccCallDisconnect:
Mar 31 04:56:45.529: //3157/B00C33DD8EA2/CCAPI/cc_api_get_transfer_info:
Mar 31 04:56:45.625: //3157/B00C33DD8EA2/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x3DAD23F0, Tag=0x0, Call Id=3157,
Mar 31 04:56:45.625: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 31 04:56:45.625: :cc_free_feature_vsa freeing 3EA08DD8
Mar 31 04:56:45.625: vsacount in free is 1
Mar 31 04:56:45.625: //3156/B00C33DD8EA2/CCAPI/ccCallDisconnect:
Mar 31 04:56:45.625: //3156/B00C33DD8EA2/CCAPI/cc_api_get_transfer_info:
Mar 31 04:56:46.633: htsp_process_event: [50/0/1.1, EFXS_OFFHOOK, E_DSP_SIG_0100]efxs_offhook_onhook
Mar 31 04:56:46.633: htsp_timer - 10 msec
Mar 31 04:56:46.645: htsp_process_event: [50/0/1.1, EFXS_OFFHOOK, E_HTSP_EVENT_TIMER]efxs_offhook_timer
Mar 31 04:56:46.645: htsp_process_event: [50/0/1.1, EFXS_ONHOOK, E_HTSP_RELEASE_REQ]efxs_onhook_release
Mar 31 04:56:46.645: htsp_timer_stop
Mar 31 04:56:46.645: [50/0/1.1] set signal state = 0x4 timestamp = 0
Mar 31 04:56:46.645: //3156/B00C33DD8EA2/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x3DFD2BF0, Tag=0x0, Call Id=3156,
Mar 31 04:56:46.645: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 31 04:56:46.645: :cc_free_feature_vsa freeing 3
Seafdec_2901VG#EA08EB8
Mar 31 04:56:46.645: vsacount in free is 0
you have missed the "forward-digits 7" on the dial peer
since this is pots dial-peer auto stripping is applied, but just to be sure i also tried your suggestion but im still getting an error:
Seafdec_2901VG#show dialplan number 93372725
Macro Exp.: 93372725
VoiceEncapPeer999101
peer type = voice, system default peer = FALSE, information type = voice,
description = `',
tag = 999101, destination-pattern = `9.......',
voice reg type = 0, corresponding tag = 0,
allow watch = FALSE
answer-address = `', preference=0,
CLID Restriction = None
CLID Network Number = `'
CLID Second Number sent
CLID Override RDNIS = disabled,
rtp-ssrc mux = system
source carrier-id = `', target carrier-id = `',
source trunk-group-label = `', target trunk-group-label = `',
numbering Type = `unknown'
group = 999101, Admin state is up, Operation state is up,
Outbound state is up,
incoming called-number = `', connections/maximum = 0/unlimited,
DTMF Relay = disabled,
URI classes:
Destination =
huntstop = disabled,
in bound application associated: 'DEFAULT'
out bound application associated: ''
dnis-map =
permission :both
incoming COR list:maximum capability
outgoing COR list:minimum requirement
Translation profile (Incoming):
Translation profile (Outgoing):
incoming call blocking:
translation-profile = `'
disconnect-cause = `no-service'
advertise 0x40 capacity_update_timer 25 addrFamily 4 oldAddrFamily 4
mailbox selection policy: none
type = pots, prefix = `',
forward-digits 7
session-target = `', voice-port = `0/0/0:15',
direct-inward-dial = disabled,
digit_strip = enabled,
register E.164 number with H323 GK and/or SIP Registrar = TRUE
fax rate = system, payload size = 20 bytes
supported-language = ''
preemption level = `routine'
bandwidth:
maximum = 64 KBits/sec, minimum = 64 KBits/sec
voice class called-number:
inbound = `', outbound = `'
dial tone generation after remote onhook = enabled
mobility=0, snr=, snr_noan=, snr_delay=0, snr_timeout=0
snr calling-number local=disabled, snr ring-stop=disabled, snr answer-too-soon timer=0
Time elapsed since last clearing of voice call statistics never
Connect Time = 0, Charged Units = 0,
Successful Calls = 0, Failed Calls = 9, Incomplete Calls = 0
Accepted Calls = 0, Refused Calls = 0,
Last Disconnect Cause is "15 ",
Last Disconnect Text is "call rejected (21)",
Last Setup Time = 14320849.
Last Disconnect Time = 14320850.
Matched: 93372725 Digits: 1 Matched pattern: 9.......
Target:
in SRST mode what can you get with "show isdn status" command ?
i did not get the status, but i was able to receive incoming call succesfully. I will be testing srst mode this evening and then i will post the result
You need to speak to your provider..Your provider is disconnecting the call and the reason is that "CALL IS REJECTED"
Your call is getting to them but they are rejecting the call. We dont know why. Get on the phone with them and confirm why this is the case..
yes i see that too, but how come i can make outbound/inbound calls when link to cucm is up (router not in srst mode)
You will need to send us same debug for calls to the same number in normal operations. Then we can compare and see the difference
and you dont having preference config on dial peers also
