HELP WITH FXS IN CUCM!!!!!
Good morning people,
I'm having a problem in the FXS ports on my router.
The problem is the following ....
The FXS extensions on the card connected the router can not make connection .... when they dial, since the busy direct. Also, they are not ringing when they receive calls ....
I thought it was routing problem, but I changed the dial-peer and to no avail.
On Call Manager, they are configured correctly with the correct Partition and CSS, and are registered.
I think it must have some relation with the stcapp .... but as they know almost nothing about him, I do not know .....
Does anyone can help me?
Bruno
Follows the configuration of the router:
POA_CUCME_VIVER#sh run
Building configuration...
Current configuration : 16400 bytes
version 15.0
hostname POA_CUCME_VIVER
boot-start-marker
boot system flash:c2801-spservicesk9-mz.150-1.M6.bin
boot-end-marker
card type e1 0 2
no aaa new-model
clock timezone BRZ -3
network-clock-participate wic 2
network-clock-select 1 E1 0/2/0
dot11 syslog
ip source-route
ip cef
no ip domain lookup
ip domain name inpar.com.br
ip name-server X.X.X.X
no ipv6 cef
stcapp ccm-group 1
stcapp
stcapp feature access-code
prefix #
call forward all 2
call forward cancel 3
pickup local 1
pickup group 9
pickup direct 1
stcapp supplementary-services
port 0/3/0
  fallback-dn 9112
port 0/3/1
  fallback-dn 9113
port 0/3/2
  fallback-dn 9123
port 0/3/3
  fallback-dn 9124
isdn switch-type primary-net5
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol pass-through g711ulaw
h323
modem passthrough nse codec g711ulaw
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class h323 1
  h225 timeout tcp establish 3
voice class custom-cptone BR-Anatel
dualtone ringback
  frequency 425
  cadence 1000 4000 1000 4000
dualtone disconnect
  frequency 425
  cadence 250 250 250 250
voice translation-rule 1
rule 1 /^\(87[5-9].\)$/ /025113046\1/
rule 2 /^\(3[0-1]..\)$/ /025113046\1/
rule 3 /^\(32[0-4].\)$/ /025113046\1/
rule 4 /^\(32[8-9].\)$/ /025113046\1/
rule 5 /^\(92..\)$/ /025113046\1/
voice translation-rule 2
rule 1 /^\(48[0-3].\)$/ /025913323\1/
voice translation-rule 3
rule 1 /^0015/ /025/
rule 2 /^0021/ /025/
rule 3 /^0031/ /025/
voice translation-profile AddAARparaBELEM
translate called 2
voice translation-profile AddAARparaSP
translate called 1
voice translation-profile TrocaOperadoraInParSP
translate called 3
voice-card 0
dsp services dspfarm
license udi pid CISCO2801 sn FTX134681EB
archive
log config
  hidekeys
username administrator privilege 15 secret 5 $1$pWFh$YAvqsQjXTcAnleUqzAQ0A/
controller E1 0/2/0
framing NO-CRC4
pri-group timeslots 1-31
interface Loopback0
ip address X.X.X.X
interface FastEthernet0/0
ip address X.X.X.X
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1/0
no ip address
shutdown
no fair-queue
clock rate 2000000
interface Serial0/2/0:15
no ip address
encapsulation hdlc
isdn overlap-receiving T302 2000
isdn incoming-voice voice
isdn send-alerting
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route X.X.X.X
control-plane
disable-eadi
voice-port 0/2/0:15
disc_pi_off
cptone BR
bearer-cap Speech
voice-port 0/3/0
cptone BR
caller-id enable
voice-port 0/3/1
cptone BR
timeouts ringing infinity
caller-id enable
voice-port 0/3/2
cptone BR
caller-id enable
voice-port 0/3/3
cptone BR
caller-id enable
sccp local FastEthernet0/0
sccp ccm 172.20.1.6 identifier 3 version 7.0
sccp ccm 10.0.100.4 identifier 1 version 7.0
sccp ccm 10.0.100.5 identifier 2 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate ccm 3 priority 3
associate profile 1 register CFB0026cb7398de
keepalive retries 5
keepalive timeout 5
switchover method immediate
switchback method immediate
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 4
associate application SCCP
dial-peer voice 100 voip
description *** CCM-01 ***
destination-pattern 91[0-2].
session protocol sipv2
session target ipv4:10.0.100.4
voice-class codec 1
dtmf-relay sip-notify
dial-peer voice 101 voip
description *** CCM-02 ***
preference 1
session target ipv4:10.0.100.5
voice-class codec 1
dial-peer voice 2 pots
description *** Chamadas Locais Fixos ***
destination-pattern 0[2-5].......
incoming called-number .T
direct-inward-dial
port 0/2/0:15
forward-digits 8
dial-peer voice 3 pots
description *** Chamadas Locais Celular ***
destination-pattern 0[6-8].......
port 0/2/0:15
forward-digits 8
dial-peer voice 4 pots
destination-pattern 09......T
port 0/2/0:15
forward-digits 8
dial-peer voice 5 pots
description *** Chamadas DDD Fixos ***
translation-profile outgoing TrocaOperadoraInParSP
destination-pattern 00[1-9]...[2-5].......
port 0/2/0:15
forward-digits 13
dial-peer voice 6 pots
description *** Chamadas DDD Celular ***
destination-pattern 00[1-9]...[6-9].......
port 0/2/0:15
forward-digits 13
dial-peer voice 7 pots
description *** Chamadas DDI ***
destination-pattern 000T
port 0/2/0:15
prefix 00
dial-peer voice 8 pots
description *** Chamadas 0300 ***
destination-pattern 00300T
port 0/2/0:15
prefix 0300
dial-peer voice 9 pots
description *** Chamadas 0303 ***
destination-pattern 00303T
port 0/2/0:15
prefix 0303
dial-peer voice 10 pots
description *** Chamadas 0800 ***
destination-pattern 00800T
port 0/2/0:15
prefix 0800
dial-peer voice 11 pots
description *** Chamadas Emergencia ***
destination-pattern 019.
port 0/2/0:15
forward-digits 3
dial-peer voice 12 pots
description *** Chamadas Servicos ***
destination-pattern 01[1-8].
port 0/2/0:15
forward-digits 3
dial-peer voice 13 pots
destination-pattern 0103..
port 0/2/0:15
forward-digits 5
dial-peer voice 14 pots
destination-pattern 0105.
port 0/2/0:15
forward-digits 5
dial-peer voice 15 pots
description *** Chamadas A Cobrar Local ***
destination-pattern 09090[2-9].......
port 0/2/0:15
forward-digits 12
dial-peer voice 16 pots
description *** Chamadas A Cobrar DDD ***
destination-pattern 090[1-9]...[2-9].......
port 0/2/0:15
forward-digits 14
dial-peer voice 1000 pots
service stcapp
port 0/3/0
dial-peer voice 1001 pots
service stcapp
port 0/3/1
dial-peer voice 1002 pots
service stcapp
port 0/3/2
dial-peer voice 1003 pots
service stcapp
port 0/3/3
dial-peer voice 300 pots
description *** AAR para SP ***
translation-profile outgoing AddAARparaSP
preference 1
destination-pattern 87[5-9].
port 0/2/0:15
dial-peer voice 301 pots
preference 1
destination-pattern 3[0-1]..
port 0/2/0:15
dial-peer voice 302 pots
preference 1
destination-pattern 32[0-4].
port 0/2/0:15
dial-peer voice 303 pots
preference 1
destination-pattern 32[8-9].
port 0/2/0:15
dial-peer voice 304 pots
preference 1
destination-pattern 92..
port 0/2/0:15
dial-peer voice 305 pots
description *** AAR para Belem ***
translation-profile outgoing AddAARparaBELEM
preference 1
destination-pattern 48[0-3].
port 0/2/0:15
dial-peer voice 306 pots
description *** Chamadas DDD InPar SP ***
destination-pattern 0015113046....
port 0/2/0:15
forward-digits 13
dial-peer voice 307 pots
description *** Chamadas DDD InPar BH ***
destination-pattern 0015913323....
port 0/2/0:15
forward-digits 13
no dial-peer outbound status-check pots
telephony-service
sdspfarm conference mute-on 111 mute-off 111
sdspfarm units 5
sdspfarm tag 1 CFB0026cb7398de
conference hardware
srst mode auto-provision none
srst ephone template 1
srst dn template 1
srst dn line-mode dual
max-ephones 30
max-dn 150
ip source-address 172.20.1.6 port 2000
no service directed-pickup
timeouts interdigit 9
system message SISTEMA EM CONTINGENCIA
cnf-file location flash:
cnf-file perphone
user-locale U1 load CME-locale-pt_BR-Portuguese-7.0.1.1.tar
network-locale U1
time-zone 19
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
call-forward pattern .T
moh flash:/its/Music-Hold/Moh_Inpar_Espera-g711ulaw.wav
multicast moh 239.1.1.1 port 16384 route 172.20.1.6 1.1.1.1
web admin system name administrator secret 5 $1$Klvo$jmPfsOul9h9uOwXlhBF3f/
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 0
create cnf-files version-stamp Jan 01 2002 00:00:00
POA_CUCME_VIVER#
Everyone's tags (5)
1 REPLY
If you debug SCCP do you see the messages coming in??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
837
