Help with MeetMe Conference (no conference bridge)
I have tried to follow the configuration guide for meetme conferencing. When i hit the meetme softkey and enter the number (888) I get the message 'no conference bridge' on the IP Phone. three-way conference calling also does not work (unable to create conference).
This is on a UC520, stripped-down config attached.
Re: Help with MeetMe Conference (no conference bridge)
Please enable a 'debug ephone detail', then recreate the problem and upload the output.
Keep in mind that G.711 conferencing is the default operation on CME; all parties in a conference call must use either G.711 u-law or G.711 a-law. No other codec is supported for conferencing. G.729 endpoints can be supported via transcoding to G.711.
The maximum number of G.711 conferences supported by CME varies by platform. If you want to adjust the maximum number of conferences sessions, you may us the following CLI:
telephony-service
max-conferences 8
Also make sure to be using the correct procedure to create and join the conference:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeconf.html#wpmkr1022626
debug attached. As far as I can tell, the phone is using G711, so it shouldn't be an issue.
this happens right in the middle of the log:
Nov 6 01:26:35.911: UpdateCallState DN 31 chan 1 operating in mode 8
Nov 6 01:26:35.911: skinny_hwcfbi_find_conferenceId_by_number: this is not an active conf number 888
Nov 6 01:26:35.911: skinny_hwcfbi_confId_to_confBlk: invalid conference id 0x0
Nov 6 01:26:35.911: skinny_hwcfbi_find_mtpcb: no MTPCB resource
Nov 6 01:26:35.911: skinny_hwcfb_get_new_conferenceId: no MTPCB available
Nov 6 01:26:35.911: skinny_hwconf_call_open:Conf Id 0 31 chan 1
Nov 6 01:26:35.911: ephone-7[7][SEP0012F04029D8]:DisplayMessageTag: tag 139 (Unknown Tag)
Nov 6 01:26:35.911: SkinnyGetCallState for DN 12 chan 1 ALERTING
Nov 6 01:26:35.911: called DN 31 chan 1, calling DN -1 chan 1 phone 7 s2s:1
Nov 6 01:26:35.911: ephone-7[7][SEP0012F04029D8]:is_auto_local 1 for DN 12
Nov 6 01:26:35.911: Skinny StartTone 37 sent on ephone socket [7] DtReorderTone
Nov 6 01:26:35.911: ephone-7[7]:CallPrompt line 1 ref 6:tag 122 (Ring Out)
Nov 6 01:26:35.911: ephone-7[7]:SelectPhoneSoftKeys set 8 mask FFFF for line 1 ref 6
Nov 6 01:26:35.915: ephone-7[7]:CallPrompt line 1 ref 6:tag 156 (Unknow number)
Nov 6 01:26:35.919: DN: 31, CHAN: 1, voice_hcmask: 0x0
Nov 6 01:26:35.919: dn_support_srtp false DN 31 chan 1 (HW conference)
Nov 6 01:26:35.919: UpdateCallState DN 31 chan 1 operating in mode 8
Nov 6 01:26:35.919: skinny_hwconf_call_end:StreamID 0. Call not in conference dn 31 chan 1
Nov 6 01:26:35.919: skinny_hwcfbi_find_conferenceId_by_number: this is not an active conf number 888
Anyone?
SOLVED
Looks like i just had to change:
sccp ccm 10.1.1.1 identifier 1
To:
sccp ccm 10.1.1.1 identifier 1 version 4.1
489
