Help with MGCP Config. Unable to recieve calls
ali
Hi All
I am not sure why I can make calls but cannot receive.
I am using a Cisco 2811 gateway router and running Call Manager 4.1
Attached is the router config.
MARTIN STREULE
If you can do outbound calls, the config on the gateway cannot be that bad. :-)
Do you have a proper CSS configured in the CCM configuration of the gateway?
Is the number of digits you receive okay and adjusted in the config?
Yes I have the CSS all configured
I am not too sure anout the number if digits question though?where do I find out that?
I am suspecting it might be something I might not have configured on the router.
When I dial any of the numbers in the telephone range I have it just says 'Number Unobtainable'
Maybe you have no "external phone number mask", so outgoing call works fine, but incoming won't match internal extension?
regards,
pk
