Help with Q931 trace
Whilst debugging an ISDN / MGCP gateway the following appeared :
Gateway#
Aug 5 13:41:37.108 bst: ISDN Se0/1/0:15 Q931: RX <- FACILITY pd = 8 callref = N/A
Facility i = 0x91A1130202400002010C300A0A01010A0103A0028100
Protocol Profile = Remote Operations Protocol
0xA1130202400002010C300A0A01010A0103A0028100
Component = Invoke component, Unsupported operation
Called Party Number i = 0x81, '9999'
Plan:ISDN, Type:Unknown
Gateway#
Aug 5 13:44:20.937 bst: ISDN Se0/1/0:15 Q931: RX <- FACILITY pd = 8 callref = N/A
Facility i = 0x91A1130202400002010C300A0A01010A0103A0028200
0xA1130202400002010C300A0A01010A0103A0028200
Called Party Number i = 0x81, '8745'
Gateway#
Aug 5 13:44:27.173 bst: ISDN Se0/1/0:15 Q931: RX <- FACILITY pd = 8 callref = N/A
Facility i = 0x91A1270202400002010C301E0A01010A0101A016A014A10F0A0102120A323037353336323330300A0100
0xA1270202400002010C301E0A01010A0101A016A014A10F0A0102120A323037353336323330300A0100
Called Party Number i = 0x81, '7404'
What does the "Protocol Profile = Remote Operations Protocol
Component = Invoke component, Unsupported operation "
Part mean, we are currently having a problem with a small number of incoming calls not connecting.
Green
Re: Help with Q931 trace
We need the call being offered since the beginning include calling, called and timestamps.
Thats just part of a call and facility messages not being understood
Below is the complete trace from one of the gateways, ie their were no existing calls or call setup attempts in progress when the debug started
gateway#
Aug 6 14:23:16.593 bst: ISDN Se0/1/0:15 Q931: RX <- FACILITY pd = 8 callref = N/A
Facility i = 0x91A1130202400002010C300A0A01010A0101A0028100
0xA1130202400002010C300A0A01010A0101A0028100
Called Party Number i = 0x81, '2066'
gateway#
581
