Community Member
Help with QoS basic configuration.
Hi all, i want to configure qos in a cisco lan with non cisco phone. I read a lot of documentation and some basic videos. I don't want to configure it very granular, so, the most basic commands that i found:
conf t
int fa0/5
switchport voice vlan 111
mls qos trust cos
auto qos voip trust
How i'm be realy sure that QoS is working on mi lan?
And how about the interface trunk configuration?
Any suggestion?
Here are the verification:
In the show running-configuration :
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos srr-queue input bandwidth 70 30
mls qos srr-queue input threshold 1 80 90
mls qos srr-queue input priority-queue 2 bandwidth 30
mls qos srr-queue input cos-map queue 1 threshold 2 3
mls qos srr-queue input cos-map queue 1 threshold 3 6 7
mls qos srr-queue input cos-map queue 2 threshold 1 4
mls qos srr-queue input dscp-map queue 1 threshold 2 24
mls qos srr-queue input dscp-map queue 1 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue input dscp-map queue 1 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue input dscp-map queue 2 threshold 3 46 47
mls qos srr-queue output cos-map queue 1 threshold 3 4 5
mls qos srr-queue output cos-map queue 2 threshold 1 2
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 3 1
mls qos srr-queue output dscp-map queue 1 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue output dscp-map queue 1 threshold 3 46 47
mls qos srr-queue output dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 2 threshold 1 26 27 28 29 30 31 34 35
mls qos srr-queue output dscp-map queue 2 threshold 1 36 37 38 39
mls qos srr-queue output dscp-map queue 2 threshold 2 24
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue output dscp-map queue 4 threshold 1 8 9 11 13 15
mls qos srr-queue output dscp-map queue 4 threshold 2 10 12 14
mls qos queue-set output 1 threshold 1 100 100 50 200
mls qos queue-set output 1 threshold 2 125 125 100 400
mls qos queue-set output 1 threshold 3 100 100 100 400
mls qos queue-set output 1 threshold 4 60 150 50 200
mls qos queue-set output 1 buffers 15 25 40 20
mls qos
In the interface configuration:
interface FastEthernet0/5
switchport access vlan 111
switchport mode access
srr-queue bandwidth share 1 30 35 5
priority-queue out
mls qos trust cos
auto qos trust
spanning-tree portfast
In trunk port:
interface GigabitEthernet0/1
switchport mode trunk
sh mls qos int f0/5
FastEthernet0/5
trust state: trust cos
trust mode: trust cos
trust enabled flag: ena
COS override: dis
default COS: 0
DSCP Mutation Map: Default DSCP Mutation Map
Trust device: none
qos mode: port-based
Thanks a lot !
Martín.
Hello Martin,
Just go through this once, this might help you
http://www.dslreports.com/faq/13324
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
Community Member
  Hi Nadeem, this is a very complete article. But i still wondering how i can be sure that QoS really works in my entire lan. I tried debug commands but didn't work.
Thanks.
One way to test your QoS configuration is with network traffic tools such as iperf (http://sourceforge.net/projects/iperf/).  You can send traffic across the network and place a phone call and see how the audio sounds.  Alternatively you can use IPSLA (http://www.cisco.com/en/US/products/ps6602/products_ios_protocol_group_home.html) to monitor your network traffic.
Community Member
Hi, thanks for reply. I investigate a little more.
When i want verify that QoS really work in the lan, first of all:
- The marking (in my case verify traffic VoIP at 64)
- Queue, that put first in the queue voice traffic, dscp 64
To try, i make a call connecting an IP phone (in fa0/6) and call to analog phone. Wait for 2 minutes and see what changes in this command:
Switch#sh mls qos int f0/6 st
FastEthernet0/6 (All statistics are in packets)
  dscp: incoming
  0 -  4 :       4465744658 0            0            0            0
  5 -  9 :           0            0            0            0            0
10 - 14 :           0            0            0            0            0
15 - 19 :           0            0            0            0            0
20 - 24 :           0            0            0            0            0
25 - 29 :           0         1196            0            0            0
30 - 34 :           0            0            0            0            0
35 - 39 :           0            0            0            0            0
40 - 44 :           0            0            0            0            0
45 - 49 :           0        41769 62163 0           91 98            0
50 - 54 :           0            0            0            0            0
55 - 59 :           0            0            0            0            0
60 - 64 :           0            0            0            0
  dscp: outgoing
  0 -  4 :      251670 272323 0            0            0            0
  5 -  9 :           0            0            0            0            0
10 - 14 :           0            0            0            0            0
15 - 19 :           0            0            0            0            0
20 - 24 :           0            0            0            0            0
25 - 29 :           0            0            0            0            0
30 - 34 :           0            0            0            0            0
35 - 39 :           0            0            0            0            0
40 - 44 :           0            0            0            0            0
45 - 49 :           0         3393            0            0            0
50 - 54 :           0            0            0            0            0
55 - 59 :           0            0            0            0            0
60 - 64 :           0            0            0            0
  cos: incoming
  0 -  4 :       89094 109541 0            0            0            0
  5 -  7 :           0            0            0
  cos: outgoing
  0 -  4 :      295699 316387 0            0            0            0
  5 -  7 :        3393            0            0
  output queues enqueued:
queue:    threshold1   threshold2   threshold3
queue 0:           2           0           0
queue 1:      209108        1534      194272
queue 2:           0           0       56565
queue 3:           0           0       33762
  output queues dropped:
queue 0:           0           0           0
queue 1:          57           0           0
queue 2:           0           0           0
queue 3:           0           0           0
Policer: Inprofile:            0 OutofProfile:            0
The underlined numbers is the variations in aprox. 2 minutes in the call. That mean that the traffic was marked as VoIP traffic, but i´m not sure that the traffic is queued right.
I´m wrong?
Thanks for the help
PS:Later monitoring: with iperf or Cacti using IP SLA.
305
