Help with setup
I'm trying to put to work a small voip setup compossed of CCM 5.0 server and a 2821 with a VIC2-2BRI card as TE (user side) and IOS 12.4(10) but its's not working when it comes to call or receive calls from the PSTN/PBX. It seems that the Route Pattern configured in Call Manager doesn't find the gateway and
viceversa. Furthermore I'm not sure whether dial peers are working. Im' using H.323 although previously I tried MGCP also.
When I call from the IP phone no call arrives to the gateway and when I call from the pbx the call does reach the gateway but not the ip phone. The gateway looks unregister in Call manager but i think this is normal in H.323, not sure.
I attach the diagram of my setup. This is the relevan part of my configuration.
Dial-peer voice 1 pots
incoming called-number 6....
direct-inward-dial
dial-peer voice 2 voip
destination-pattern 6...
session target ipv4:10.10.5.1
no digit-strip
dial-peer voice 3 pots
destination-pattern 9...
port 0/0/1
no digit-strip
gateway
int G0/1
ip address 10.10.5.2 255.255.255.0
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.10.5.2
interface BRI0/0/1
no ip address
isdn switch-type basic-net3
isdn protocol-emulate user
isdn layer1-emulate user
isdn incoming-voice voice
Re: Help with setup
The gateway looking unregistered is indeed normal for H323. I would suggest looking at your partition/call-searching-space configuration as from the config and what you describe the gateway doesn't seem to be at fault.
Are the partitions that the phone and the route pattern are in reachable via the configured CSS?
Hope that helps,
Doug
Re: Help with setup
Yes, I'm just using one partition and search space and all the phones ang gateway are in this space. In fact the Call Analyzer reports Routed Call. If there were that kind of problems I think it reports a Blocked Call.
Re: Help with setup
I know it sounds simple but I gather you've tested IP connectivity between Phone and Gateway?
Re: Help with setup
If you get a chance could you post the result of a "debug voip ccapi inout" when the call is failing from Gateway > CM?
Doug
Re: Help with setup
Hi, thanks for your suggestions. Now I'm able to receive calls!!!, but still I can't call outside. When I dial from IP phone, I don't see any activity in my gateway using either debug voip ccapi inout or debug isdn q931.
Which other troubleshooting tool may I use? Maybe it has to do with the route pattern configured in my Call manager 9xxx
Re: Help with setup
What string are you dialing exactly from the IP Phone?
Can you post a screenie of your route pattern config?
Doug
Re: Help with setup
Hi, I send you attached a couple of screens, one corresponding to the route pattern and the other is the relevant part of the route plan report (this last one doesn't look very right).
Find next also the debug isdn q931 when I type the command 'csim start 9721'
*May 30 13:07:07.511: ISDN BR0/0/1 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Called num 9721
*May 30 13:07:07.511: ISDN BR0/0/1 Q931: TX -> SETUP pd = 8 callref = 0x03
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x81
Called Party Number i = 0x80, '9721'
Plan:Unknown, Type:Unknown
*May 30 13:07:07.547: ISDN BR0/0/1 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x83
Cause i = 0x81E404 - Invalid information element contents
Re: Help with setup
At this point, the calls reach the gateway so according to the last part of the debugging in my previous message maybe it's rather a problem with the info that is sent from the gateway and that is not complete from the pbx point of view. What do you think?
Re: Help with setup
Thanks for the screenies. I've had a browse around and have found the following URL:
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a0080093f62.shtml
I know this references Netmeeting but the principle and setup is the same as your example.
I would suggest looking at Solution 2 and overwirting the bearer-cap on the Q931 setup message on the outbound voice-port.
Let me know if this works.
Doug
Re: Help with setup
Hi Doug,
finally the last problem had to do with the compand law, which I have just configured as A (instead of u) and it's working.
Thank you.
132
