Community Member
Help
Have a customer who is experiencing call disconnects when they place an outside call on hold for about 30 sec. CallManager is 5.1 and gateway is using MGCP.
Anyone have any ideas about this?
1 ACCEPTED SOLUTION
VIP Purple
Re: Help
Try the following command on your gateway.
no mgcp timer receive-rtcp
Hope this helps. If so, please rate the post.
Brandon
VIP Purple
Re: Help
Brandon
Community Member
Re: Help
That worked! What does that command do?
Thanks so much for your help.
Chris
VIP Purple
Re: Help
Chris,
This command turns off the timer for RTP/RTCP packets. Without this command, the call will be disconnected after a period of receiving no RTP/RTCP packets. While the call is on hold, it is receiving these packets from the MOH server. Take a look at the following link.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_command_reference_chapter09186a00801a7f2e.html#wp1370227
Hope this helps.
Brandon
Community Member
Re: Help
Thank you so much for the reply!
Chris
Community Member
Re: Help
I have similar problem with a h323 gateways. calls are disconnected in different periods of time, between 2 min to 28 min.
CCM Version: 4.2(3)sr2b
h323 Gateway IOS Version: c2800nm-advipservicesk9-mz.124-17.bin
Any suggestions appreciated.
Carlos
103
