HelpRqd:For Conference & PBX Integration
1. Conference 3 way. Am send the config of both the routers
2. Key system/ PBX connectivity. The Toplogy is as follows.
AnalogPhones<--->SamsungNX-820-PBX<---->ATA186<--->Switch-RtrA(CME4.0)<--->WAN(512kbps)<--->RtrB<--->FxO<-->PSTN
Pl. Help with the right commands. for 3 way conference local and Internatinal
Bask
1 REPLY
Silver
Re: HelpRqd:For Conference & PBX Integration
The Cisco DPA 7630 and 7610 Voice Mail Gateways (DPA 7630/7610) enable you to integrate Cisco CallManager systems with Octel voice-mail systems, which might also connect to either Definity or Meridian 1 PBX systems. This integration enables you to use your existing third-party telephony systems along with your Cisco IP telephony system.
For example, you can ensure that features such as message-waiting indicators (MWI) for Octel voice messages are properly set on Cisco IP Phones (connected to Cisco CallManager) and traditional telephony phones (connected to Definity or Meridian 1 PBX systems).
Using the DPA 7630/7610, you can integrate the following systems:
Cisco CallManager 3.1(1) or higher
Octel 200 and 300 voice-messaging systems (using APIC/NPIC integration)
Octel 250 and 350 voice-messaging systems (using FLT-A/FLT-N integration)
Definity G3 PBX systems (DPA 7630 only)
Meridian 1 PBX systems (DPA 7610 only)
This URL should help you:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00801ec5c0.html
98
