12-27-2011 06:55 PM - edited 03-16-2019 08:43 AM
I have several route patterns in CUCM7. I have the usual 11,10, and 7 digit route patterns. As soon as I dial the last digit of either of those patterns, the call goes to my CUBE and out to my SIP trunking provider right away. However, I am also testing an integration with Microsoft Exchange Unified Messaging. I setup an simple route pattern that uses a 4 digit number that points to the SIP trunk going towards the Exchange Server. Now, until yesterday, the connection fired up right away after I entered the 4th digit of the pattern. I had to rebuild my server and now there is a good 5 second delay before the call actually goes through. Any ideas of where I can start troubleshooting? Thanks!
Robert
Solved! Go to Solution.
12-28-2011 07:19 AM
As suggested earlier if there is a reason for you to keep these "open" route patterns you can uncheck "urgent" checkbox from it and check it on the shorter more explicit patterns, this way CUCM is not going to wait for all 7 digits when dialing specific strings that match more explicit urgent patterns.
HTH,
Chris
12-27-2011 08:59 PM
Have you already looked into overlapping issues?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
12-27-2011 09:04 PM
Below is what I have for route patterns. I really don’t see any overlapping patterns, unless I am looking at this wrong.
1[2-8]XXXXXXXXX 11 Digit Dialing 192.168.2.4
9000 ATW Exchange UM 192.168.16.6
911 911 Dialing 192.168.2.4
XXXXXXX Local 7 Digit Dialing 192.168.2.4
XXXXXXXXX 10 Digit Dialing 192.168.2.14
Robert
12-28-2011 12:44 AM
Try setting Urgent checkbox in route pattern.
12-28-2011 07:05 AM
That's the first and most common error when troubleshooting overlapping.
Your dial plan is not just your route patterns, your dial plan is ANYTHING you have configured that has a pattern/DN.
java
If this helps, please rate
12-28-2011 07:08 AM
Yeah, I took another look at what I had. It never dawned on me. My 7 digit dialing was the culprit. The system was waiting on my to finish the remaining 3 digits after dialing 9000 and when it timed out, it reverted back to the 9000 route pattern. I removed the 7 digit RP and it went through instantly.
Robert
12-28-2011 07:19 AM
HTH,
Chris
12-28-2011 07:36 AM
Ahhh, I see. I might give that a shot. I’m gonna test it again later today. Thanks for your help (both of you).
Robert
