Hide on Hold display
ncreamer
I am looking for a way to hide the large on hold display on 7960's. I want it so that you get the on hold icon next to the DN and the flashing light, just not the large screen that indicates on hold.
virverma
Level 4
Level 4
could you explain by sending a picture, as far I guess its working as designed
Sure, see the picture attached, I want the red box to not be there when a call is on hold and but the blue box information to stay.
No way to modify the behavior, it's WAD
java
if this helps, please rate
java
