Community Member
Hide users on CUCM 6.1.3
Hi all,
I need to hide users from being seen from corporate directory option on IP phones but in the same time users like "JTAPI" user should functions well without any problems.
I have CUCM 6.1.3
Any ideas,
Ahmed Kamal
Community Member
Re: Hide users on CUCM 6.1.3
You can create another container in AD and move users you want to hide from their. You also need to make sure the new container is not in the LDAP user search base.
HTH,
Randall
Community Member
could you tell the procedures in details?
Community Member
HI,
You need to check the LDAP Directory. In CUCM check system/LDAP/LDAP Directory. It is probably pointing to tiyr Users container.
If so, create a container in AD and call it say, Hidden users, and move your users over there.
Then do a LDAP sync on the LDAP directory and they should be hidden
Randall
327
