Hiding incoming caller id display on 7906/7941's
esmythe
This is pseudo-related to my last topic on scripting ani/dnis info.
This is regarding a 2811 CUCME 4.1 system with a T1 CAS PSTN connection.
All incoming calls flash as coming from '911'. How can I disable or modify this? (Users are accidentally calling 911 when browsing call history.)
thx,
-e
mwild
I went into my Route Pattern for 911 and picked "block this pattern" now when someone dials 911 is just drops. I do have 9-911 setup though.
Aaron Dhiman
Level 2
Level 2
If your GW is H.323, you can change the ANI easily on the gateway. If it is MGCP, you can do it with a Translation Pattern.
