High Availabilty CUBE
I have a pair of CUBE devices (3925 devices running IOS Version 15.1(4)M2) configured & licenced for HA mode using HSRP and redundancy.
I have one interface registering to an ITSP through a firewall, the other interface is SIP trunked to a PBX through another firewall.  This architecture cannot be changed...
config snippets
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
! to do - secure down to trusetd host
address-hiding
mode border-element
allow-connections sip to sip
! no H323 in this environment
redundancy
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface GigabitEthernet0/1
  bind media source-interface GigabitEthernet0/1
  error-passthru
dial-peer voice 200 voip
translation-profile outgoing SIP_OB
preference 1
destination-pattern .T
b2bua
session protocol sipv2
session target sip-server
session transport udp
voice-class sip dtmf-relay force rtp-nte
voice-class sip profiles 200
voice-class sip bind control source-interface GigabitEthernet0/1
voice-class sip bind media source-interface GigabitEthernet0/1
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 101 voip
  translation-profile outgoing SIP_Trunk
destination-pattern 8.T
b2bua
rtp payload-type nte 120
session target ipv4:x.x.x.x
session transport tcp
voice-class sip bind control source-interface GigabitEthernet0/0
voice-class sip bind media source-interface GigabitEthernet0/0
dtmf-relay rtp-nte
codec g711alaw
fax-relay ecm disable
no vad
My issue is with the binding of the HSRP address to the SIP packets;  the way this is currently configured is that the packets routing to the ITSP have an IP source of the "external" interface's (gi0/1) HSRP address - as required by ITSP (and firewall rules).  However, packets routing to the PBX from the "internal" interface (gi0/0) are also sourced from the Gi0/1 HSRP address and consequently are dropped by the internal firewall.
What I need is the CUBE to source the IP Packets from HSRP address of the interface that they leave on.  Is the only way to achieve this to source nat them? or am I missing something fundamental?
i dont think you can source a traffic from HSRP VIP address !
you might use a loopback but this wont be a good option for your design !!
you could try NAT
SIP & NAT do not play nice: This is kinda the reason for CUBE, after all ;-)
GTG
Please rate all helpful posts.
442
