High bandwidth b/w call managers
hi all
we have noticed high bandwith b/w cucmbe and cucmpub on random ports. what traces should i collect on cucmbe, since the traffic is origination from cucmbe to cucm.
What do you have configured between the two clusters??
It'll be easier if you just get a sniffer to see exactly what traffic you're sending.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
thanks javalenc
the only communication b/w cucmbe and cucm cluster is thru ICT non gatekeeper control trunk. would any kind of traces help me here?  also if i set up sniffer how would i do that since the issue is intermittent. and let say i did, should i use cli command on cucmbe (where the traffic is originating) to capture packets also could this impact disk capacity in cucmbe.
Exactly how much is high BW from what you mention???
It could be either MTP, MOH or something similar
java
java
236
