High IOWAIT: CiscoDRFMaster writing logs like crazy
We have a CUCM 8.6.2.22900-9 running, but this issue also occured when it was just version 8.6.2a.
Our CUCM seems to be rather slow, and when I open the RTMT it says we have high IOWAIT. To verify this, I went to the System Status and I see the IOWAIT is 35%. Now I take a look at the Process list in RTMT, and it seems the CiscoDRFMaster process is using up 30-35% CPU time.
To see what it's doing, I opened the Cisco DRF Master logs from the last 5 minutes. It appeared that this process is writing EIGHT 1MB logs every SECOND, and it's completely filled with this error:
2012-08-30 10:37:26,066 DEBUG [NetServerClient-krecucm01] - drfNetServerClient. Reconnect: Object InStream to be created
2012-08-30 10:37:26,066 DEBUG [NetServerClient-krecucm01] - drfNetServerClient.run, caught general exception from host: [krecucm01], message: null, cause: null
java.lang.NullPointerException
Does anyone know what this could be?
Ruud van Strijp
Everyone's tags (4)
Dou you have any kind of traces enabled for the DRS services?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi java,
Thank you very much, somehow logging indeed was enabled for this service. Disabling tracing caused the IOWAIT to drop back to below 1%.
However, this didn't solve the issue of the service running at high CPU usage. This is even 49% at the moment, I guess because it's still generating issues, just not logging those.
Ruud van Strijp
Last week we upgraded to CUCM 9.0.1-37, but I still have these issues. Our CPU load is very high (70%), all caused by the CiscoDRFMaster service running on 50% CPU usage.
Are there any logs I can check to see why the DRFMaster would use so much CPU?
Ruud van Strijp
1213
