Hold and tranfer botton fails
DO you know why sometimes the HOLD and TRANSFER botton is unavailable when is an active call and I try to HOLD the call.
Re: Hold and tranfer botton fails
Hi Maiden013,
Is this Call Manager or Call Manager Express?
Also what version of Call Manager is this and What version firmware are you using?
Justin
Sound like calls using H323 with no MTP
java
if this helps, please rate
java
www.cisco.com/go/pdi
Is call manager 6.1, all the MTP, CFB, Transcoding resources all configured in Software(ccm) and Hardware(gateway 3845).
Have you got a MOH resource added to your MRGL?
Please remember to rate useful posts, by clicking on the stars below.
Yes, is added too.
any idea?
MTP required checked in GW config?
MTP available in MRGL?
If you check the app log is it full of MTP errors??
java
java
yes
yes
How can I see the log?
What firmware version are your phone's using?
200
