Community Member
Hold and Transfer doesnt work for specific type of call in a sip trunk.
I have a curios case with the hold and transfer features in cme and 3905 sip phones. There is not sccp phones.
The SIP SP give us a sip trunk with two headers, 3185840 and 3185860. I already setup the AA for both numbers.
Incoming Calls from SIP TRUNK.
When a called number is one of the headers, the transfer and hold works fine.
If the called number is another number using DID, 3185861 for example, the hold and transfer doesn’t work.
When the I pick up the phone, and press the hold (or transfer) , 3905 softkey the call is dropped. The calling party hears a busy tone.
The translation rule for the incoming dial-peer is simple, rule 1 /^.*\(....\)/ /\1/ , that rule just take the last four digits of the called number. The last four digits match with the phone extensions.
The attached debug has two scenarios:
  • •1.       Calling number ( xxx-4339866 )
  • •2.       Called number 3185861. (hold and transfer doesn’t work). Reason: Q.850;cause=65
  • •3.       Called number 3185860. Hold and transfer works fine.
  • •4.       The final number (transfer) extension 5863.
Please I need some help, thanks.
Everyone's tags (5)
Cause code 85 is a media negotiation failure.  Sound like a possible codec mismatch.  Do you have an MTP configured?
Community Member
I have configured conference resources.
no xcode. May be the problem is a mistmatch between the codec listed in the voice class codec
and the dspfarm profile 1 conference:
voice class codec 1
  codec preference 1 g711ulaw bytes 160
  codec preference 2 g729br8 bytes 20
  codec preference 3 g711alaw bytes 160
  codec g729br8
  codec g729r8
  codec g729abr8
  codec g729ar8
  codec g711alaw
  codec g711ulaw
  maximum conference-participants 8
  maximum sessions 1
I will change that config and I will let you know.
Thanks.
Community Member
Solved with :
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
  g729 annexb-all
789
