Holiday - Cicso Business edition 7
I have just been told  we need to modify the "holiday schedule" or phone times for our building that is closing early on Thursday 24th and Thursday 31st December.
Thursday 24th - phones to switch over  at 10am
Thursday 31st  - phones to switch over at 3pm
OR - Is there a way the receptionists can do this manually?
Many thanks in advance
1 ACCEPTED SOLUTION
Re: Holiday - Cicso Business edition 7
thats good
could you please rate the helpful post
thank you
hi
the question is in normal cases during after working hours what happen to the calls when it come to the rceptionist number ?
i am just asking to see what type of night service or after hours treament you have i the system
any way one of the best ways you can use if time of day call routing feature see the bellow document might be helpful
https://supportforums.cisco.com/docs/DOC-8294
good luck
if helpful Rate
Any way you want to do this needs someone to configure stuff in CUCMBE, then the recepcionist could forward to a call handler depending on what you want to do.
Basic options would be
a) follow the holiday guide for CUC
b) configure a CTI RP with CFA to VM and catch the call in CUC with a recording of holiday then hang up, send them to other place, etc
c) same as b) but use TOD instead of having recepcionist CFA to CTI.
1st and 3rd options are automatic, 2nd option requires the recepcionist to CFA at the proper time
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Thanks  for your help - I have sucessfully setup the times i needed
thats good
thank you
449
