Homologação de Servidores HP
Ola,
Gostaria de saber se o modelo HP DL-580 G7 é homologado para rodar CUCM 8.6.2. Existe alguma lista de Servidores não MCS ou UCS, homologados para rodar não só o CUCM, como Unity, UCCX, etc...
Obrigado,
Wilson
1 ACCEPTED SOLUTION
There are HW compatiblity guides per product, review those as they're all available online, and the virtualization wiki provides all the info on TRC, TRC spec based, and 3rd party spec based. Hailey already provided you with that link on another thread.
HP/IBM to MCS compatibility is here:
http://www.cisco.com/en/US/products/hw/voiceapp/ps378/product_solution_overview_list.html
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
1 REPLY
java
java
103
