Hook flash with H323 FXO
Does anyone know if there is a way to send a hook flash to the PSTN via an H323 FXO. I want to be able to dial a feature code on an ip phone (connected to CCM) and have that translated into a hook flash to be sent to the FXO connected to the PSTN.
Glenn
5 Replies 5
sbilgi
Level 5
Level 5
Try the bug Id CSCdv73539 Hookflash from mgcp to h323 gateway fxs fails to complete... The on-hook delay after hookflash will be necessary b/c CCM does not complete the transfer until we receive some notification of call proceeding from the destination.
The problem is that I do not know how to send a hook flash from an ip phone.
Glenn
Did you ever find a solution to this?
Christopher,
Have a look at this link
http://www.cisco.com/c/en/us/support/docs/voice/h323/15405-pbx-across-ip.html
Alex
Regards, Alex. Please rate useful posts.
FYI I was successfull getting that to work. We then customized a button to use XML url to use the senddigits to emulate a Link button.
