host names for CUCM 5 or 6
Tommer Catlin
Anyone know or remember when installing CUCM 5 or 6 if it accepts capital letters or small case or a combination when entering in the hostname?
Thanks!
Jaime Valencia
as far as i remember all you suggest is supported, only the use of underscore is not supported
java
if this helps, please rate
jbarcena
Level 9
Level 9
"The host name can comprise up to 64 characters and can contain alphanumeric characters and hyphens"
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/5_0/cmins504.html
As already stated it does not support special characters.
