Hosted Voip for Small Business
We are looking for a hosted voip solution for small businesses (Less than 25 phones) that can use Cisco IP phones, not SPA phones.  Does anyone have any experience with any reliable options?
Everyone's tags (1)
You can get a 2901 or 2911
You can get a 2901 or 2911 and run Cisco Call Manager Express.
http://www.cisco.com/c/en/us/products/collateral/routers/2900-series-integrated-services-routers-isr/data_sheet_c78_553896.html
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm.html
HTH Regards,
Yosh
HTH Regards, Yosh
I'm looking for something
I'm looking for something that is hosted.  Internet based.
Take a look at West IP - http
Take a look at West IP - http://westipc.com/
Hailey
Thank you David!  I will look
Thank you David!  I will look into this one.
No problem - the West IP
No problem - I believe their UC service offering is called MaxxPoint...has a lot of features and they've been around a while. They are a Cisco partner and a Gartner leader in UCaaS.
Hailey
hi+5 for Yosh , as he
hi
+5 for Yosh , as he mentioned you can go to Cisco CME solution which is router based . You can use Cisco router 2nd generation as 2901 , or 2911 .You have to ask yourself one question regarding if you will need a service module for voice mail , or not . you have also to do a survey for no.of users which will be supported by your CME in future . Kindly check the below link which will inform you more information about each series .
thanks
please rate all useful information
I'm quite familiar with CME.
I'm quite familiar with CME.  I've deployed it many times.  It's not always the correct solution even for a small business.  I have more than one scenario where a CME isn't an option.  For example. I have a business that has 10 users that all work from home.  They would like a central phone number and extensions for each employees desk phone.  Also, shared VM.  This all needs to be cloud based.
183
