How add a new subscriber on Cluster
Hey team,
I have been working on CUCM cluster with Publisher and 2 x Subscribers. (System version: 8.6.2.23900-10)
Now, I need to add a new subscriber in the same cluster. (I have node license available)
I have started all services and the new subscriber server apper in available Cisco Unified Communications Managers.
But when I move the new subscriber into the group and I click in save I receive the error:
Update failed. TypeDbErrors.CMGM_LIMIT_EXCEEDED
thanks.
1 ACCEPTED SOLUTION
The SRND discusses this, there are many ways to handle this, if you want 1:1 HA, 2:1, etc
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
How many servers do you already have in the CUCM group??
java
java
I have 1 Pub + 2 Subscribers working
So, I have been trying to add one subscriber more..
You can only have 3 servers in a CUCM group.
java
java
Ok, I created 2 groups like that:
GroupA = Pub + Sub01
GroupB = Sub02 + Sub03
So, How Can I create a HA inter groups?
If my devices registered on groupA have problem to reachable Pub or Sub01. How Can I do that devices to register on group B?
thanks.
They cannot, you can only have 1 CUCM group and 3 choices in it for any device.
java
java
Ok, but is there any documentation about this design?
What is the best design for 4 CUCM servers?
I have been thinking to register 50 % of the devices in groupA and 50% in the groupB.  (CUCM solution balanced)
thanks
java
java
152
