Community Member
How can i block the IE Facility Display Name on a mgcp gateway
Hello ,
Caller ID name is sent by our telco ( IE Facility ) and we want to block this on the IP Phone. The Gateway is controlled by mgcp.
All the checkboxes under "PRI Protocol Type Spezific Information " are unchecked .
Se0/0/1:15 Q931: RX <- SETUP pd = 8  callref = 0x7100
        Bearer Capability i = 0x9090A3
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA18382
                Preferred, Channel 2
        Display i = '123456  123456'           #   we want block this number
        Date/Time i = 0x0C061D0C2824
                Date (dd-mm-yr)   = 12-06-29
                Time (hr:mnt:sec) = 12:40:36
1 REPLY
Under MGCP endpoint config you can choose to change or block calling/called name/number. Just adjust as you want those parameters.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
430
