How can I clear a SHOW EPHONE output ?
I need to know is there a command to delete the show ephone output for the unregistered phones.
R_VOZ_JGS#show ephone
ephone-1 Mac: TCP socket:[-1] activeLine:0 UNREGISTERED
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0
IP:0.0.0.0 0 Unknown 0  keepalive 0 max_line 0
ephone-2 Mac: TCP socket:[-1] activeLine:0 DECEASED
IP:10.1.9.54 16223 ATA Phone keepalive 5 max_line 2 dual-line
ephone-3 Mac: TCP socket:[-1] activeLine:0 UNREGISTERED
IP:10.1.9.54 3970 ATA Phone keepalive 18 max_line 2 dual-line
VIP Purple
Hi ,
can u try clear voice register attempted regsitration or clear telephony-service ephone-attempted-registration command ?
regds,
aman
I have tried the commands but it only clears the statistics for the attempted-registerations. So unfortunately that didn't work for me.
Hi Smita,
I think there is no way to remove ephone stats other than removing ephone from the config or you can filter your result by
sh ephone registered and sh ephone unregistered.
Manish
Hi Manish,
I can do that but currently it will show me as 122 unregistered phones because they were in SRST, but not anymore and I want to clear that.
Smita
Hi Smita,
If you really need to clear those logs then try reloading the router ,this only option left for you.
rate all the helpful post.
Manish
Thanks Manish..
I was able to find the solution for it rather than rebooting. I did no telephony-service and then pasted all the commands of the telephony service, so I was able to remove all the ephones.
R_VOZ_JGS(config)#no telephony-service
Skinny Deleted entries for 6 phones
VIP Purple
Hi Smita,
Thanks for update.
regds,
aman
Yes "no telephony-service" will remove all config from telephony service. I would not recommend that command in production router just for clearing the logs but glad that it helped you.
Manish
I agree with you Manish, but since my phones are not going to SRST mode at the moment, so I was good at it . I immediately put back all the 19 commands I had configured and I was good to go
Hi +5 Smita.
Manish
415
