Community Member
how can i configure After Hours Call Blocking for the SIP Phones
I'd like to  configure  After Hours Call Blocking for the SIP Phones but i can't find the pin command
Hall of Fame Super Silver
Re: how can i configure After Hours Call Blocking for the SIP P
CUCM or CME?
Community Member
Hi Chris
I have the same issue on CME .
Community Member
I'd like to  configure  After Hours Call Blocking on CME for the SIP Phones
What version of CME do you have?  CME 3.4 and newer offers after hours call blocking to SIP phones, see below:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeblock.html#wp1010373
HTH,
Chris
Community Member
I have CME 8.6
the Doc tells that The Login toll-bar override is not supported on  SIP IP phones; there is no pin to bypass blocking on IP phones that are  connected to Cisco Unified CME and running SIP
the sip support after-hour exempt only but how can i use pin and login like the SCCP
666
