Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
How can I configure an IP trunk between UC520 and Avaya CM ?
I am trying to connect a new UC520 to an Avaya CM 4.0 installed in the building via IP trunks so the cisco users can communicate to the avaya users by dialing the 4 digit extension (the pbx's extension plans do not overlap) rather than wasting 2 telephone lines and dialing an outside line. Is there an easy way to do it or can someone point me to a guide for implementing the h.323 or SIP trunks between the two?
I used Google for you
Try this:
http://www.cisco.com/en/US/solutions/collateral/ns340/ns414/ns728/ns829/785594.pdf
-- please remember to rate and mark answered helpful posts --
Damian,
Please remember, Cisco documents such integrations with 3rd Party products at a portal called as " Cisco Interoperability Portal ". Your required document can be found under section " Cisco Unified Communications Manager Express " as UC520 runs on CUCME.
GP.
Pls rate helpful posts !!
188
