how can i configure extension mobility in CCME
hello,
i have CCME 4.2 and i want to configure the extension mobility.
can you post me the configuration that i can put in the router.
thanks in advance.
Hall of Fame Super Gold
Re: how can i configure extension mobility in CCME
Link to documentation with examples:
http://cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmemobl.html#wpmkr1130585
thanks for reply,
the document is not understandable.
please post me the configuration of EM.
thanks a lot.
Which part do you not understand? There is a complete configuration example in there, have you tried ?
hello,
i don't understand the type of number (silent, beep, ...)
because this think is not present in Cisco Call Manager.
thanks.
Here the description for button command that is the equivalent of "type" in EM configuration:
http://cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_b1ht.html#wp1067478
Suggest that you begin configuring with "normal" ring. Then depending on the phone type, and user request, you can do more advanced configurations.
As an appreciation to those providing answers, please rate posts using the scrollbox below!
hi
will test it tomorrow, and i will post you the result of the test
thanks for your helping.
hi,
i have configure the EM within the CCME, but the problem is when i log into the phone, the number place is empty.
the configuation is : voice logout-profile 1
pin 12345
user badr password badr
number 123 type normal
voice user-profile 1
pin 12345
number 4123 type silent-ring
ephone 1
mac-address 0019.E8C8.5707
type 7961
logout-profile 1
help me please.
136
