Community Member
How can I find unassigned number?
Is there any solution to find unassigned number for created translation patterns? I used route plan report, but it's so informational as I wanted
1 REPLY
VIP Super Bronze
Re: How can I find unassigned number?
what information do you want.
Route plan report is the only tool that helps you find all the patterns defined in your cluster
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
172
