Community Member
How can i have access the sql device table from CLI, for CCM6.1
hello,
last time i have added one device phone and i try to change something i cannot, it said ma duplicate value.
it's any possibility to remove this phone from the CLI.
Green
Re: How can i have access the sql device table from CLI, for CCM
we normally use "run sql" command from CLI, then sql statement
you can run some queries to display the value that is duplicate run sql select * from device etc//...
Which value you are trying to change\modify?
could you plese send us an screenshot?
it is possible but you require to get rid of all the references from the phone in several tables depending on what it has configured, if you have services and other stuff you would require to modify about 5 tables for 1 phone.
it would be easier if you mention what's the exact issue you're facing and the version for us to provide help, it might be a simple bug or there could be another workaround
java
if this helps, please rate
java
www.cisco.com/go/pdi
158
