Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
How can i install ip communicator 7.0 as SIP Endpoint on CUCM 7.1?
What should i do for this???...what is the step-to-step??
Re: How can i install ip communicator 7.0 as SIP Endpoint on CUC
Use Migrate Phones - SCCP TO SIP from BAT
Make sure you have read the SRND endpoint chapter to understand what you cannot do when using CIPC as SIP
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Thanks a lot, however i have a mistake on the subject because i need to install ip communicator 7.0 as SIP Endpoint on CUCM 4.2. Is it compatible??...how can i do the installation???...the same as you said before, do not??
Once again thanks for you help.
Then the answer is NO, SIP endpoints only with CUCM 5.X and above
java
If this helps, please rate
java
304
