How can i know how many phone license i have
Dears
I have CME 2811
which command can verify phone quantities for the installed license
in UC5XX the command "show platform software license"
Thanks in advnace
3 ACCEPTED SOLUTIONS
Hall of Fame Super Silver
You cannot, CME licenses are Right To Use licenses (paper licenses) that are not applied to anything.  You would need to look at original quotes.
HTH,
Chris
VIP Purple
Re: How can i know how many phone license i have
Hi Zaher,
As explained by Mr. Chris (+5), u need to check the order placed to Cisco since CME/SRST licenses are paper and honour based.
Had it been ISR G2 , you could have run commands to check what all licenses are available in permanent and Eval mode.
regds,
aman
Hall of Fame Super Gold
amanso@hcl.in wrote:
Hi Zaher,
No. On both ISR G1 and G1 "phone licenses" are exclusively paper, and cannot be "seen" in any manner.
HTH,
Chris
Hi Chris
kindly look to an actual example
Upgrade license              : uc500-16u-upgrade
License UDI                  : UC520W-8U-4FXO-K9 :FHK11351185
License status               : Not in Use
Maximum User Licenses        : 14
Used User Licenses           : 12
Available User Licenses      : 2
System upgraded atleast once : No
it will gives you the maximum user licenses the same of what i need but for 2811 not for UC5XX
this command only supported on UC5XX series not on the others
Question was about CME specifically not UC500.
Chris
What I have a cisco 2811
what i need to know
the maximux, used and the remaining users for it
Thank you
VIP Purple
Hi Zaher,
regds,
aman
Hi Zaher,
VIP Purple
Hi Paolo,
What I was referring to show license all and show license detail commands in ISR G2 which gives output of what all features are activated and are in temporary/permanent mode?
I agree with you , that CME and SRST licenses in ISR G2 are Paper and RTU based.
regds,
aman
282
