Community Member
how can i reach my voice mail form outside of the office
hi,
I got 2851 ccme and cue.
config is below
in the office i can dial 7000 and i can reach my voicemails but how can i reach from out of the office..
my DID range 3555700-5799
and ephone-dn s are 57xx-5799
dial-peer voice 2001 voip
destination-pattern 5700 >>AA number
session protocol sipv2
session target ipv4:172.30.10.133
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 200 voip
destination-pattern 7000>>Voice Mail number
codec g711ulaw
no vad
dial-peer voice 1 pots
description calls over pri
translation-profile incoming prefix
destination-pattern 9T
direct-inward-dial
port 0/0/0:15
thanks a lot
Community Member
Re: how can i reach my voice mail form outside of the office
Looks like your voicemail number is out of your DID range.
You got 2 choices, either change 7000 to an extension within your DID range. Or, you can assign a DID number for it, say 5701 and add a translation rule to translate 5701 to 7000.
Eugene
Community Member
hi,thanks for your answer
you mean config should be like that?
am i right i should apply the rule in the sip dial-peer an as outogoing?
thanks again.
voice translation-rule 10
rule 1 /5701/ /7000/
voice translation-profile to_voicemail
translate called 10
TRANSLATION-PROFILE OUTGOING to_voicemail
codec g711ulaw
no vad
Community Member
Sorry I'm still pretty green in translations, but it looks good to me.
How about this, add another dial-peer like:
codec g711ulaw
no vad
dial-peer voice 201 voip
destination-pattern 5701
codec g711ulaw
no vad
Eugene
248
