How can I receive fax Store and Forward and Voice calls on the same gateway
just configuring FAX store and forward on one of my voice gateways
but I can only receive voice calls or FAX store and forward calls, depending on my inward call dial peers I thought having 2 dial peers thecall would drop through to the second one but it doesnot.
here are the dial peers
dial-peer voice 2111 pots
service onramp
incoming called-number .
dnis-map faxnumbers
direct-inward-dial
port 2/0:15
dial-peer voice 1001 pots
service Default
prefer 1
direct-inward-dial
port 2/0:15
is there a way round this ? or do i have to use the fax detect TCL?
richard
1 REPLY
Re: How can I receive fax Store and Forward and Voice calls on t
Answer my own question
I was trying to match the called number to the number after the num-exp command had taken place, on doing a 'debug voice dialpeer'
i found infact for inbound dial peers the match on the incoming called number is done before the num-exp takes place,
now works as it should.
Richard
170
