How can i register a cisco phone at home remotely to office uc520
Hi ,
I have a site in Dubai with UC520 and one user is in Oman can we give one cisco phone to his home and required one 800 series router with 3g
How can i make register the phone with dubai UC520  . Can we create a VPN on the UC520 to that 800 series router . And can i connect the
phone on directly to router ethernet port .
Breeze Joseph Kuriakose Sr Network Engineer
Yes this will work!
You can create a site-to-site VPN from the 800 to the UC520 and put the IP of the CME(UC520) as option 150 in the DHCP configuration at the remote site. You should also be able to ping the UC520 from a PC at the remote site.
If you work with 3G on one site, be aware that some provider use NAT and only give private IPs to the 3G devices. In this case you need to make sure that the remote site initial the VPN to the UC520.
Christian
- Please rate helpful posts -
888
