01-15-2008 02:43 AM - edited 03-15-2019 08:13 AM
I have CCME, and i want implement B-ACD, my need is for each call, the greeting must be heared and after that the call must be routed to the receptionist.
I have tested the following config, but it doesn't work :
dial-peer voice 1000 pots
service aa
port 0/0/0:15
direct-inward-dial
incoming called-number 022203304
ephone-hunt 10 sequential
pilot 5071
list 5011
timeout 10
application
service callq flash:app-b-acd.tcl
param queue-manager-debugs 1
param aa-hunt1 5071
param number-of-hunt-grps 1
param queue-len 10
service aa flash:app-b-acd-aa.tcl
paramspace english language en
param aa-pilot 022203304
param service-name callq
param handoff-string aa
param second-greeting-time 60
param drop-through-option 1
param drop-through-prompt _mag_prompt.au
param call-retry-timer 15
param max-time-call-retry 700
and when i want to verify this services
with the command show call application sessions, the services already created are not displayed.
Thnaks for help
01-15-2008 04:46 AM
Hi, please set param voice-mail to some value as the error above suggest.
01-15-2008 05:01 AM
thanks for reply, it works from inside because we have dial-peer voice 1000 voip, but from outside it only rings, and no greeting is heared.
01-15-2008 05:17 AM
Usually that is because the incoming DP fails. Make sure the called number, incoming called in DP, and aa-pilot do match.
01-15-2008 05:24 AM
the dial-peer and the aa-pilot match correctly.
is the DP pots or voip that i must configure ?
thanks.
01-15-2008 05:39 AM
pots DP. Verify with debug isdn q931 the called number is what you have configured.
01-15-2008 06:37 AM
i have configured this :
dial-peer voice 1001 pots
service aa
when i verify with debug, the called number is always 022203304, but it can't rings.
01-15-2008 06:45 AM
With debug voip application script you should see BACD-AA kick in. If it doesn't, either the number is not right, aa-pilot mismatch, etc.
