07-08-2013 07:54 PM - edited 03-16-2019 06:17 PM
Hello
I have phones 7941,7942,7962 , my Cisco Router is 2911 .
I would like access from the phone to a directory where I can pull name and extension in order to make internal calls.
what is the setting i need to do in order to achieve this task>
Thanks so much in advacnce.
Vic
07-08-2013 08:11 PM
Guess you might be looking for this...
http://www.cisco.com/en/US/products/hw/phones/ps379/products_configuration_guide_chapter09186a00800adf13.html
07-09-2013 01:43 AM
Hi Victor.
I guess you are configuring a CUCME.
Please refer to the following guide.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmedirs.html#wp1015876
Please rate all helpful posts
"The more you help the more you learn"
07-09-2013 02:25 AM
config t
ip http server
telephony-service
directory entry 1 14045550111 name Sales
directory entry 2 13125550122 name Marketing
directory entry 3 12135550144 name Support Center
service local directory
create cnf
exit
restart the phones
To verify
show running-config
show telephony-service
show telephony-service directory-entry
You are limited in no of directory entries in telephonyservice
You can use external directory entry for more entries using an sql database
Router(config)# telephony-service
Router(config-telephony)# url directories http://10.0.0.11/localdirectory
Please rate if this helps, by clicking the stars below.
07-09-2013 02:37 AM
Thank you so much for your help guys. i will be checking on this and update the thread . Appreciate a lot
07-11-2013 09:55 AM
I got stuck in the first step
Step 1
Double-click the TabSyncInstall.exe provided by your system administrator.
where can i get this one?
07-15-2013 06:30 PM
Pls go through this...
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7960g_7940g/7_0/sip/english/administration/guide/7960infS.html
