Community Member
how configure jabber android to cme 9.0 - router 2911?
I have a router 2911 and I want to configure jabber to android smartphone ? What write in the device name ? I really appreciate your help. Thank you.
Jabber for Android is only supported with CUCM
System requirements
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/jabber/Android/8_6/Cisco_Jabber_Android_8_6_2_RN.html#wp46650
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Community Member
Re: how configure jabber android to cme 9.0 - router 2911?
I have that information in the cme 9.0 ok
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(3)T1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 13-Jun-12 14:24 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
CME_HTC_LA_PAZ uptime is 12 hours, 1 minute
System image file is "flash0:c2900-universalk9-mz.SPA.152-3.T1.bin"
Last reload type: Normal Reload
Last reload reason: power-on
voice register global
mode cme
source-address 192.168.2.1 port 5060
bandwidth video tias-modifier 900000 negotiate end-to-end
max-dn 50
max-pool 50
authenticate presence
authenticate register
authenticate realm cisco.com
hold-alert
tftp-path flash:
create profile sync 0009082271491446
voice register dn  4
number 412
allow watch
name Karoll Trujillo
label Karoll Trujillo
voice register pool  4
registration-timer max 720 min 660
id device-id-name SEP0C715D65DB07
session-transport tcp
type Jabber-Android
number 1 dn 4
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
And the document of cisco refer about jabber for android to cme 9.0, with that type of cellphone I want to try ?
Community Member
FUNCIONA EN UN MINI GALAXY  +++++> ANDROID
Community Member
Hola, hablas español?Se que
Se que el tema es viejo pero yo recién intento hacer funcionar el cliente Jabber en Android. He podido registrar un par de teléfonos y logro hacer la llamada saliente, pero cuando me contestan no escucho al otro interlocutor, ellos a mi si.
Tuviste exito con tu mini galaxy?
Community Member
CME 9.0 can integrate smartphone with SO  Android. I can register Andoid Mini Galaxy in CME 9.0
Community Member
add new config
username 412 password 412
create profile
or
id mac 0C715D65DB07
then
create profile
3191
