How configure siemens hipath SIP trunk
hi all
i wish know how configure SIP trunk with Siemens hipath 4000, some example configuration or way.
THX
Re: How configure siemens hipath SIP trunk
Configure the SIP trunk on the Siemens itself or on a Cisco device, such as CME or CM?
hi, i need to know how configure in Cisco Call Manager 5.1 with Siemens Hipath 4000 via SIP trunk, without using E1 QSing.
I would not recommend doing a direct SIP trunk from CM to the Hipath. You will be really limited to what you can do with it. Your best bet is to use a CUBE to interface between the two systems. However, QSIG is the recommend integration type of a Siemens PBX. Here is one document that may help.
http://www.cisco.com/en/US/solutions/collateral/ns340/ns414/ns728/ns833/698642.pdf
Here is another link that may be useful.
https://www.myciscocommunity.com/message/8955;jsessionid=574712FBC179928F2D521F7FB506F30F.node0
Hi, thanks for the reply, but using E1 controller i will limited for 30 calls only, maybe 15 in / 15 out, and that's not good for me. i have more than 500 Ip phones in both sides, (Siemens and CCM).
i hope you can help me.
Thx.
Have you checked Siemens docs?
Regards.
Look on Interoperabilty Portal. There are many examples between cisco devices and others supply.
http://www.cisco.com/en/US/netsol/ns728/networking_solutions_program_category_home.html
Att
Peterson
2292
