How do I convert a Cisco 186 ATA from a SCCP image to SIP
In the Upgradeing the Cisco ATA Signaling Image documentation it gives me two
options.
Upgrading the Signaling Image from a TFTP Server
Upgrading the Signaling Image Manually
I have been following the Manual process. I have downloaded different versions of the SIP image. I have run the command ata186us ......zup
I have run the command 100# ip_address......
But keep getting the message "Upgrade Failed"
Can anyone give me any ideas or help???
THanks
1 REPLY
Re: How do I convert a Cisco 186 ATA from a SCCP image to SIP
Out of curiosity, have you looked through the admin guide?  Here's the link:
http://www.cisco.com/univercd/cc/td/doc/product/voice/ata/ataadmn/sip30ad/sip88ch3.htm#wp1044846
You might want to try the tftp method to see if you have better luck.
494
