Community Member
How do I enable to calling a phone number without changing Partition/CSS?
Hello everyone,
I got a extension that needs to call a special phone number.
The calling searching space doesn't include this phone number.
Is there any solution if I don't need to change CSS?
Howard
VIP Purple
Re: How do I enable to calling a phone number without changing P
Howard,
One solution is to create a translation pattern that is in a partition that the CSS of the phone does have access to. You can give the translation pattern a CSS which has access to the partition of the special number.
Hope this helps. If so, please rate the post.
Brandon
Community Member
Thank you for your reply.
Actually I create a route pattern for the specific number, and assign the same CSS to the extension. And it works properly.
Howard
104
