How do I get two lines enabled on an analog phone connected to a vic3 4fxs/DID in a 3845 router?
I currently have one line enabled only. I did not do the configuration for that line, and the person who did has left the company. How do I enable the second line? There is no power going to the second line (no lighting of light on phone for line 2) and there are 4 lines in the phone wire.
Thanks for your help
Could you post the configuration?  Is this an h323 or MGCP gateway?
The FXS ports won't light up unless the port is active (off-hook) so it may be working.  If I can see the config I should be able to help further.
Gregory,
    Here is what I currently obtained. Let me know if you need to see more. The light I was talking about is the one on the phone itself. I do take it off hook on both lines. It only lights up and gets dial tone on line 1.
Config data:
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
--More--                           !
voice-port 0/2/0
description Primary Telephone x1000
station-id number 1000
caller-id enable
voice-port 0/2/1
description Secondary Telephone x1001
station-id number 1001
caller-id enable
voice-port 0/2/2
description FAX x1002
station-id number 1002
caller-id enable
voice-port 0/2/3
dial-peer voice 1000 pots
description Primary (Telephone x1000)
destination-pattern 1000
port 0/2/0
dial-peer voice 1001 pots
description Secondary (Telephone x1001)
destination-pattern 1001
port 0/2/1
dial-peer voice 1002 pots
description FAX (FAX x1002)
destination-pattern 1002
port 0/2/2
VoiceEncapPeer1000
peer type = voice, system default peer = FALSE, information type = voice,
description = `Primary (Telephone x1000)',
tag = 1000, destination-pattern = `1000',
voice reg type = 0, corresponding tag = 0,
allow watch = FALSE
answer-address = `', preference=0,
CLID Restriction = None
CLID Network Number = `'
CLID Second Number sent
CLID Override RDNIS = disabled,
rtp-ssrc mux = system
source carrier-id = `',          target carrier-id = `',
source trunk-group-label = `',          target trunk-group-label = `',
numbering Type = `unknown'
group = 1000, Admin state is up, Operation state is up,
Outbound state is up,
incoming called-number = `', connections/maximum = 0/unlimited,
DTMF Relay = disabled,
URI classes:
    Destination =
huntstop = disabled,
in bound application associated: 'DEFAULT'
out bound application associated: ''
dnis-map =
permission :both
incoming COR list:maximum capability
outgoing COR list:minimum requirement
Translation profile (Incoming):
Translation profile (Outgoing):
incoming call blocking:
translation-profile = `'
disconnect-cause = `no-service'
advertise 0x40 capacity_update_timer 25 addrFamily 4 oldAddrFamily 4
mailbox selection policy: none
type = pots, prefix = `',
forward-digits default
session-target = `', voice-port = `0/2/0',
direct-inward-dial = disabled,
digit_strip = enabled,
register E.164 number with H323 GK and/or SIP Registrar = TRUE
fax rate = system,   payload size =  20 bytes
supported-language = ''
preemption level = `routine'
bandwidth:
    maximum = 64 KBits/sec, minimum = 64 KBits/sec
voice class called-number:
    inbound = `', outbound = `'
dial tone generation after remote onhook = enabled
mobility=0, snr=, snr_noan=, snr_delay=0, snr_timeout=0
Time elapsed since last clearing of voice call statistics never
Connect Time = 260219, Charged Units = 0,
Successful Calls = 0, Failed Calls = 1, Incomplete Calls = 0
Accepted Calls = 70, Refused Calls = 0,
Last Disconnect Cause is "10  ",
Last Disconnect Text is "normal call clearing (16)",
Last Setup Time = 296462640.
Last Disconnect Time = 113618794.
Bronze
Drew,
The VIC3-4FXS is intended to support a single phone per port.  While you could technically share the same pair for two phones, this would not be ideal.  The best way to handle this would be to use another port on the card, if available.
You may be thinking of the old VIC-2FXS cards where you could have a line1/line2 on port 0, but I'm not aware of any other card supporting two lines on a single port.
-- -Mark Turpin
Hall of Fame Super Red
Hi Drew,
This sounds like more of a physical/wiring issue than a config issue (perhaps )
On a two-line analog phone that has a 4-wire cord they usually pin-out as follows (on cord);
Green - Tip line 1
Red - Ring line 1
Black - Tip line 2
Yellow - Ring line 2
So you need to to get the line 2 circuit from the FXS to the cross connect panel & to the jack that the
phone plugs into (probably on the White orange/orange white pair in the jack) this should then connect to the Black/Yellow of the 4-wire line cord to supply line 2 to the phone.
Does this make any sense?
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
A quick way to test this is to take the device that is connected to the "working" port and try it in the other ports.  See if the problem follows the device or stays with the ports.
442
