How do I get Unity Connection to register to SUB when PUB is down
All versions are 8.6 All phones and Unity register to Publisher. When I shut Pub down, all phones register to SUB like they should and everything keeps working, except Unity Connection. What am I missing as far as the config to get Unity to register to SUB when PUB goes down? Of course I built my VM ports and VM pilot number in PUB to begin with. When everything is running and I log into SUB, it shows Unity registered to PUB's IP addr. Please point me in the right direction. Thanks!
2 ACCEPTED SOLUTIONS
Hall of Fame Super Silver
There are two pieces to this, first with SCCP you need to ensure the VM ports reference DP that has more than one CM assigned. Second, the port group on UCXN need to be defined to point to more than one CUCM server.
HTH,
Chris
Hall of Fame Super Red
Hi there,
In addition to the good info from Chris & Kenneth (+5 )
Can you check these settings in CUC for the "Secondary" CUCM server config;
Step 32 On the Edit Servers page, do the following substeps if the Cisco Unified CM cluster has secondary servers. Otherwise, skip to Step 33.
a. Under Cisco Unified Communications Manager Servers, click Add.
b. Enter the following settings for the secondary Cisco Unified CM server and click Save.
Table 6-16     Settings for the Cisco Unified Communications Manager Servers
Field
Setting
Order
Enter the order of priority for the Cisco Unified CM server. The    lowest  number is the primary Cisco Unified CM server, the higher    numbers are  the secondary servers.
IP Address or Host Name
Enter the IP address (or host name) of the secondary Cisco Unified CM server.
Port
Enter the TCP port of the Cisco Unified CM server that you are     integrating with Cisco Unity Connection. We recommend that you use  the    default setting.
TLS Port
Enter the TLS port of the Cisco Unified CM server that you are     integrating with Cisco Unity Connection. We recommend that you use  the    default setting.
Server Type
Click Cisco Unified Communications Manager.
http://www1.cisco.com/en/US/docs/voice_ip_comm/connection/7x/integration/cucm_sccp/guide/cucintcucmskinny050.html
Cheers!
Rob
"I don't know how, I don't know when
But you and I will meet again "
- Tom Petty
Re: How do I get Unity Connection to register to SUB when PUB is
How do you have your telephony integration setup?
HTH,
Chris
Hi there,
Field
Setting
Order
Port
TLS Port
Server Type
Cheers!
Rob
- Tom Petty
You guys are great. Thanks! It was something just as simple as going into the VP port config in UC and adding another server and it's ports (My SUB), then resetting the original VM ports.
Thanks so much!
252
