How do I mask a Local Directory Number on CUCM 6.0.1?
Samuel Akindele
I want to mask a Local Directory Number on my CUCM 6.0.1, how do I go about it?
7 Replies 7
Brandon Buffin
Calling out to the PSTN or to another internal phone?
Brandon
to internal phones
Take a look at the following doc.
https://supportforums.cisco.com/docs/DOC-3029
Hope this helps.
Brandon
Here's some more detail.
Call Display Restrictions
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_2_1/ccmfeat/fshosp.html
Brandon
i think this will do it.
William Bell
If you mean how do you maske the CLID from an IP phone to a PSTN number, then you can do this in the following places:
1. phone line
2. route pattern
3. route list/route group
4. gateway
If you mean how do you mask numbers for internal (phone-to-phone) calls then you can use translation patterns.
Could you provide more specifics on what you are looking to accomplish?
HTH.
Bill
Please remember to rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
I want to mask to internal (local) phones
