Community Member
How do I play a prompt file?
I see several prompts and they are named as certain dates.wav.  I'm trying to find the after hours prompt but don't know how to play a prompt from the CUE GUI.  Is this possible?
thx
1 ACCEPTED SOLUTION
Re: How do I play a prompt file?
Todd,
Are you looking at the files on the System -> Prompts page? If you are, you can safely download them to your desktop using the GUI and listen to them, they will still remain on the system. Just check the box of the one you want to download and then press 'Download' at the top of the page.
You can also transfer them to your PC (if it is running a FTP server) using the CLI.
example: ccn copy prompt Prompt.wav url ftp://10.1.1.10/MyPrompt.wav username me password pw
Adam
Please rate if helpful
Hall of Fame Super Gold
You must be familiar with the internals of the CUE (file structure and naming) to play system prompts. Cisco recommends agaist that because they can change without notice.
Community Member
Ok.  If I were to download the prompts, will this simply copy them to a location (my desktop) or will the prompts be removed from the flash?
thx
You cannot access system prompts from GUI or CLI.
That's why I said you have to be familar with the internals to be able to know their names and how to access them.
Community Member
any suggestions for a beginner?
Record your own prompts and do not rely on system ones.
Todd,
Adam
Community Member
Hey thanks. That worked great.
444
