How do I provide Dial tone on E&M T1
I have 1 third party IVR connected to an H323 gateway via a Digital T1 E and M winkstart port.  I can make calls to the IVR but when a person tries to zero out, it tries to transfer call but it is not working.
The vendors says that I need to provide dial tone. How would I do that?
controller T1 0/0/1
clock source internal
ds0-group 0 timeslots 1-24 type e&m-wink-start
description IVR
This feature worked when connected to a MGCP gateway in a 4.2(3) environment.
Hall of Fame Super Gold
Re: How do I provide Dial tone on E&M T1
To my knowledge, no dial-tone is ever provided in E&M.
Beside, if the call is completed already, no dialtone should be ever further provided.
Likely there is another cause than what the IVR vendor is claiming.
You are correct.
Here is what we have found.
The IVR is dialing the five extension ie 70002. However, the gateway is receiving the 7 and then trying to match dial peers on the seven. It is like it is not waiting for the other digits
Have any ideas.
Are you using MGCP or H.323?
In either case, one should look at your dialplan configuration.
To the person that rated my post above a "3", since the information I gave is 100% correct and made with the will to help, please avoid subrating my posts in the future.
Here is what we found.
The VRU was performing a hook flash and then sending DTMF digits.  So, we had to install a TCL script on the gateway in order for the blind transfer to work.
In the debugs you should see the
hookflash from the IVR, check the duration.  The defa
ult hookflash timer is 150-1000 msec, if it's shorter it will be ignored, if
longer it will be considered a disconnect
439
