Community Member
How do I "record a live call" to unity connection 7.1 ?
Does anyone have a link showing the configuration of this feature or even if CUC version 7.1 supports it without a 3rd party application ?  Thanks.
1 ACCEPTED SOLUTION
Re: How do I "record a live call" to unity connection 7.1 ?
Configuring Live Record
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/administration/guide/7xcucsag170.html#wp1071465
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
java
java
Community Member
Thanks for the quick reply.  The instructions provided worked 100%.  Have a good day,  Denise
343
